Plastic piano hinge
Postby Geron » Sat Jun 07, 2008 6:56 pm
Mark Freedom wrote:
Geron wrote:
Mark Freedom wrote:Are you guys using a sealer of some kind under the plastic hinge to keep water from rolling under it?
Butyl putty tape has a proven track record. A strip of AL bar on top keeps the hinge from rippling.
G
Edited:
OOPS! 3 min apart on the posts.
I use Butyl putty 'cause I usually have to take mine apart twice ;) ;)
You know, "The Village Idiot"
g
Sounds like a plan.
I'll be moving back to your neck of the woods if I ever get my house sold here.
Was kind of looking at the banks county area, seems to be more tax friendly.
Lived in Dawsonville from 86 through 98.
Thanks for the tips guys.
Hey Mark,
Welcome back to North Georgia. Less see, Banks county, That's over around Commerce and Homer if my memory serves me right. I've lived in Gainsville and Jefferson just south of you there.
Had a first cousin grew up in Boise. Visited him once when I was 16 -- stunning country there around the Snake River.
Geron
If it's not broken, you're not trying hard enough.
Geron
Images: 173
Postby johnb » Sat Jun 07, 2008 9:54 pm
Wow thanks for all the great feedback.
Butyl Putty tape is a new one for me, sounds like a good idea - where do I come across this, is it a standard hardware store item?
I have the harsh-environment hinge from McMaster-Carr part number 1588A73 to qoute their web site:
Made of tough polyolefin plastic, these hinges resist saltwater, oil, most chemicals (including solvents), temperature extremes, and damaging UV rays. All of the hinges have rigid leaves and a flexible webbed middle instead of a pin. The pinless design results in smooth, silent operation. There are no mounting holes—surface mount hinges using adhesive, screws, nails, or other fasteners. Can be cut with a box cutter or razor. For indoor and outdoor use. From the folded position, the range of motion is 360° . Temperature range is -40° to +180° F.
I guess one solution is to make it so it is easy to replace in case something gives.
John
johnb
Images: 19
Postby emiller » Sat Jun 07, 2008 10:19 pm
You can get that putty tape at your local Rv supplier or alumunm supplier.
emiller
Images: 157
Postby madjack » Sat Jun 07, 2008 10:41 pm
emiller wrote:You can get that putty tape at your local Rv supplier or alumunm supplier.
...my local ACE Hdw carries it as well...it should be a fairly common item........... 8)
Postby Airspeed » Sun Jun 08, 2008 12:48 pm
Why not just use an aluminum hatch hinge and not worry about it? I dont understand the benifit of the plastic hinge, is it cheaper or is there some other reason to use it?
Thanks, Aaron
Airspeed
Images: 16
Postby Steve_Cox » Sun Jun 08, 2008 1:21 pm
Airspeed wrote:Why not just use an aluminum hatch hinge and not worry about it? I dont understand the benifit of the plastic hinge, is it cheaper or is there some other reason to use it?
Thanks, Aaron
Minimal exposure of the hinge used for its sensori-emotional values. Aesthetics, dude. 8)
Steve_Cox
Images: 196
Postby Geron » Sun Jun 08, 2008 1:50 pm
Yeah, what Steve Said plus it just simply CAN't EVER leak --no way. Therefore seals out any cold air. etc. etc.
Sensori-Emotional Values :lol: :applause: :thumbsup:
Geron
Geron
Images: 173
Postby Airspeed » Sun Jun 08, 2008 2:13 pm
"Minimal exposure of the hinge used for its sensori-emotional values. Aesthetics, dude."
Far out man! Thats way cool and Groovy!
Airspeed
Images: 16
Postby madjack » Sun Jun 08, 2008 10:37 pm
...it's just different...and a 50' roll costs about what a 5' Hurricane hinge does.......... 8)
Postby daddiozz » Wed Jul 23, 2008 9:03 pm
Looks like just the thing for my PVC/TTT :) ...you guys got a link or 2 were I can get a couple?....ooops nevermind ,I found the McMasters site ....geez just what I need ...another playground to play in... ;)
daddiozz
Images: 5
Postby madjack » Wed Jul 23, 2008 10:31 pm
...another source is http://www.monroeengineering.com/hinges ... -hinge.htm you havvta buy a 50' roll but the cost is about the same as a 5' Hurricane hinge and not much more than buying just 5' from McMaster......
madjack 8)
Users browsing this forum: Bing [Bot] and 5 guests
