one wire yellow running lights..
Anything electric, AC or DC
Postby kayakrguy » Tue Jun 10, 2008 6:42 am
I gotta ask...what's with the one-wire yellow running lights? couldn't they put in TWO brown wires at least?! With the molded plastic case, you can't really add a ground wire because then water will get in the light. So, you gotta depend on the screw to the frame for the ground. aaarrgh.!
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Re: one wire yellow running lights..
Postby Steve_Cox » Tue Jun 10, 2008 6:59 am
kayakrguy wrote:I gotta ask...what's with the one-wire yellow running lights? couldn't they put in TWO brown wires at least?! With the molded plastic case, you can't really add a ground wire because then water will get in the light. So, you gotta depend on the screw to the frame for the ground. aaarrgh.!
Jim
I had one wire running lights that I mounted on the wood side of my TD. Had to run a second wire from the mounting screw under the light. Can't see it, just went out and looked.
Steve_Cox
Images: 196
Postby bobhenry » Tue Jun 10, 2008 7:20 am
Had a tail light on my truck that simply refused to work due to a bad ground. I re routed the ground wire directly to the socket and secured it with a mini worm clamp ( hose clamp ) and then reinstalled the bulb before tightening the clamp. So just drill a small hole and install a ground as I did . A dab of silicone will seal the hole. Just a thought :oops:
Postby Dale M. » Tue Jun 10, 2008 10:03 am
Jim
Works fine on probably 98 % of the trailers the are designed to be put on.... Find another brand/style..... IF not adapt....
Dale
Dale M.
Images: 18
Postby AmyH » Tue Jun 10, 2008 10:28 am
What type do you have (can you post a pic?)? Most of the running lights I bought did not come with ground wires, so I added the ground wires myself, with a little creative tinkering. There may be a way to do that on your lights.
Amy
"...follow humbly whereever and to whatever abyss Nature leads, or else you shall learn nothing." T.H. Huxley
Photo Log
Camping Trips with the Tear
AmyH
*The 300 Club
Postby Dean_A » Tue Jun 10, 2008 12:16 pm
It takes a bit of looking, but I was able to get all my lights with separate ground wires so I didn't have to deal with the whole trailer-as-ground issue.
Dean_A
Images: 55
Postby jeep_bluetj » Tue Jun 10, 2008 3:50 pm
My trailer was chassis ground, so it was easy for most of the lights:)
But for my 2 running lights, they were mounting to wood. I merely put a ring connector on a ground wire and attached the mounting screw for the light through the ring connector. Once you pop the cover off the light, it's usually obvious how the ground connection gets made. Every one-wire light I've seen is grounded through one of the screws.
-- Jeff --
jeep_bluetj
Return to Electrical Secrets
