madjack wrote:...I usually coat with urethane or epoxy but have been considering the "asphalt fence post" paint.......
TPMcGinty wrote:madjack wrote:...I usually coat with urethane or epoxy but have been considering the "asphalt fence post" paint.......
The asphalt based fence post paint is supposed to work on both metal and wood.
Rockguy wrote:I see most everyone uses roofing tar for the underside of the floor. Has anyone used the spray undercoating, pro's, cons?
Jst83 wrote:You're supposed to undercoat them![]()
BPFox wrote:I wouldn't recommend the undercoating. Buy good plywood and let it breath. No trapped moisture, no rot. Just one man's opinion and I'm sure I am in the minority. Such is life. Peace.
Lgboro wrote:A long time local RV dealer suggest that I use the mesh like material
almost all of the RV use to protect the bottom of their RVs. He is like the
Fred Sandford of RV dealers and keeps a bunch of used RV parts along
with most new parts. I am planning on buying a used piece of this
material that he claims will allow the floor to breathe while protecting from
damage. So far his advice has been backed up by my brother and others
in the RV industry. He has years of experience with conversions and
building horse trailers, etc. as well as campers.
