Rear Lights!
Rear Lights!
Postby Creamcracker » Thu Jul 03, 2008 6:43 pm
Would you believe 2 days in the making/fitting of the mounting blocks. Right now they are test mounted-- need to skin the baffle and wire before final mount. This is just the mounting block that I made on the passenger side.
With the light loosely fixed and surround in place they look like this.
I'm really getting excited about the way NAPSACK is turning out!
Creamcracker
Teardrop Graduate
Images: 142
Postby john » Thu Jul 03, 2008 7:52 pm
sweet :thumbsup: :thumbsup:
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby doug hodder » Thu Jul 03, 2008 8:30 pm
Philip...nice way of taking care of a little detail! Those are the little things that add up to a nice trailer. :thumbsup: Doug
Postby mikeschn » Thu Jul 03, 2008 8:38 pm
Yep those adapters turned out real nice. Takes a lot of time to make em huh? How much would you sell them for? :?
Postby madjack » Thu Jul 03, 2008 8:42 pm
...as is oft said...the devil is in the details...and that is one devil of a detail...very nicely done :thumbsup: ............. 8)
Postby mechmagcn » Thu Jul 03, 2008 8:57 pm
Like Mike said, How Much?????
That looks like some great work.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby DezPrado » Fri Jul 04, 2008 6:32 am
Nice work! You must have the patience of a saint.
What type of light is that you're using, LED?
DezPrado
Postby Miriam C. » Fri Jul 04, 2008 8:13 am
mikeschn wrote:Yep those adapters turned out real nice. Takes a lot of time to make em huh? How much would you sell them for? :?
Ditto! Or could you post a picture of how you made them? 8) REally nice detail.
Postby looped » Fri Jul 04, 2008 1:43 pm
i really like the way those turned out. i might do something similar to mine that way i can put the plate higher up and out of the way of the lift handle.
great pic!
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby prohandyman » Fri Jul 04, 2008 3:25 pm
Very nice work. I too had to make an adapter for my "teardrop tailight"
Dan
prohandyman
Images: 785
Postby Creamcracker » Fri Jul 04, 2008 5:07 pm
Not sure I'd want to sell them...but you're right they did take some patience. Those are LED lights as someone spotted. I think they're going to look good when lit up.
As to how then try this -- se if you can understand:
After construction it was several coats of paint -- primer first then the top coat. The white rubber is designed for doors but it worked.
After glueing the piece together the trick then is to cut the curve at either end of the light. To do thisI placed a piece of scrap wood under the to crosspiece so that it sat level on the bandsaw table. You can temporarily fix it to the block with duct tape to make it easier.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Re: Rear Lights!
Postby ArtMini » Sun Jul 13, 2008 7:24 pm
I love those lights....... I was thinking of making fins .... like on an old Cadillac. I thought it would look so cool sticking out from the curve of the hatch. But I was concerned about holding them on securely. I'm still haven't decided but there's still time.
Art
Creamcracker wrote:Would you believe 2 days in the making/fitting of the mounting blocks. Right now they are test mounted-- need to skin the baffle and wire before final mount. This is just the mounting block that I made on the passenger side.
HAVE FUN STORMING THE CASTLE!!!!
ArtMini
Images: 16
Postby halfdome, Danny » Sun Jul 13, 2008 9:50 pm
I admire those who take the time to do the job right. You'll forget how long it took & you'll always get kudos on the visual effect. Nice job :thumbsup: Danny
halfdome, Danny
*Happy Camper
Images: 252
