Under My Skin?
Under My Skin?
Postby Seth A » Sat Jul 19, 2008 4:21 am
:) what should be done under the Al skin? Do most leave it bare wood? or seal it? I plan on Spar Urethane on the sides that will be left wood but should I use the same to seal underneath the aluminum skin on the roof? I seems that any water underneath would quickly degrade bare wood. Thoughts? :thinking:
Seth A
Postby PaulC » Sat Jul 19, 2008 7:12 am
Seth, you've answered your own question 8) Just do what you will be comfortable with. If you're worried about a little bit of water getting in then seal it first. If you think the contact will seal it, then do that.
Me, I seal every bit of timber on my TD's before I cover them.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby del » Sat Jul 19, 2008 2:13 pm
I know this is not a tear, but it shows where water can creep. The dark areas of the wood are caused by rot, and can be torn apart by your fingers.
nuf said? del
del
5000 Club
5000 Club
Images: 410
Postby madjack » Sat Jul 19, 2008 11:52 pm
Seth, I believe in sealing it all...kinda like suspenders ANDDA belt :D ;) .................................. 8)
Postby Dean_A » Sun Jul 20, 2008 12:08 am
I just used more of the spar varnish I used for everything else. Not sure it's the best thing, but it's what I had.
Dean_A
Images: 55
