Top to teardrop
Top to teardrop
Postby Dragonryder » Wed Aug 13, 2008 10:51 am
Has anyone used the rubber membrane covers for the top of their teardrop? I need to attach it to plywood. What do you guys use to cover the wood? I'm not covering my tear with aluminum, I'm just painting it. At least for now. I found a brush/roll on rubber for roofs that is supposed to work. Any one have any other ideas?
:thinking: :thinking: :thinking: :thinking: :thinking: :thinking: :thinking:
Have a great day and hoping the weather is great no matter where you are!!!
Signed, Me
Dragonryder
Images: 19
Postby mikeschn » Wed Aug 13, 2008 5:46 pm
It's not much but here's a tidbit on alternative skinning...
http://www.mikenchell.com/weekender/skinning.html
You might want to PM Bev for details on her PVC or Chip for details on his TPO.
Postby mechmagcn » Wed Aug 13, 2008 6:12 pm
I hope to install the EPDM rubber roof on my tear by this weekend. The material I have is left over from a RV roof job, but you might find some scraps at a roofing co. that installs rubber roofs. A teardrop roof really doesn't require that much material.
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Dragonryder » Thu Aug 14, 2008 10:51 am
I've heard of the Dr. Rot CPES. I think it is a bit pricey by the time you buy the filler, CPES and top coat. I'm guessing I would need the two gallons. Ouch!!! 184 dollars for 2 gallons. I guess anything you pick will probably be pricey.
I was thinking of using Kilz exterior house paint on the walls but I need something to seal the seams on the roof. I figure that I paint my garage with exterior paint and it is over ten years old. I'd like to eventually put aluminum on it but that will have to wait for another year or so. I was reading where someone was putting the rubber membrane on their camper and was wondering if that would work on a teardrop.
Just kicking around some different ideas. :thinking:
Signed, Me
Dragonryder
Images: 19
Postby Cliffmeister2000 » Thu Aug 14, 2008 11:37 am
Dragonryder wrote:I've heard of the Dr. Rot CPES. I think it is a bit pricey by the time you buy the filler, CPES and top coat. I'm guessing I would need the two gallons. Ouch!!! 184 dollars for 2 gallons. I guess anything you pick will probably be pricey. :thinking:
I am in process with the Rot Doctor products. Have one coat of CPES (took over 1/2 gallon of mixed product to cover once), and using the FILL-IT epoxy fill now. It is hot here, so I am mixing very small amounts and working fast. I did about 75% of the fill last night, it was sandable this morning. Will finish the fill process tonight, sanding this weekend, use the balance of the CPES to coat the sanded areas. Next weekend will be the application of the Uniflex 255 Aliphatic top coat. I have 2 gallons.
It is expensive, but as I read about so many folks having water issues that I don't want to have, I want to make sure I have done everything I can to do this part right the first time.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby b.bodemer » Thu Aug 14, 2008 11:41 am
I'm building a convertible td and for sure wanted to protect the edges of the side walls.
I decided on epoxy. I have a Rockler store near me and picked up some West System epoxy. Matter of fact it worked so nice I used epoxy on the exterior surfaces as well.
You can then paint over the epoxy...............
Barb
b.bodemer
Images: 328
Postby Cliffmeister2000 » Thu Aug 14, 2008 12:06 pm
Just to make sure I was clear, all the Rot Doctor products I mentioned are epoxy based.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby Dragonryder » Thu Aug 14, 2008 12:58 pm
Hey Cliffmeister2000, If you were able to do your camper with 1 gallon of CPES, I probably could do mine with that much. Your tear looks to be about the same size as mine. I hear ya on the wanting to get it right. Not that there aren't other effective methods out there but I have heard so many good things about this product (Rot Dr.). I think I will save the money up and get this product. I just want this camper to last. I'm thinking that I probably won't be ready until sometime late fall or early winter. With the winters we have here in Ohio, I probably won't be able to put a good coat on it until early spring. No big deal really, I don't want to rush it at this point in the game.
Be sure to let me know what you think about it. :thumbsup:
Signed, Me
Dragonryder
Images: 19
Postby Cliffmeister2000 » Thu Aug 14, 2008 2:48 pm
Dragonryder wrote: With the winters we have here in Ohio, I probably won't be able to put a good coat on it until early spring. No big deal really, I don't want to rush it at this point in the game.
The CPES has a consistancy like water, or turpentine. How much it takes is a component of the square footage you are covering and the thirstiness of the wood being applied to. Also how much end-grain you are applying it to, as end grain is thirstier.
There is a cold weather formula of CPES made specifically for OHIO.
I will have used $108 worth of this by the time I'm done.
Oh, yeah, you will lose a bit onto the floor because this stuff is runny, so cover the floor if you care. If you use it in an enclosed area, wear a good mask. It wasn't too bad in my open garage applying it, but the garage is bug free now, I'll guarantee! Man that stuff puts out the fumes as it cures!
http://www.rotdoctor.com/products/cpes.html
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby len19070 » Thu Aug 14, 2008 5:11 pm
mechmagcn wrote:I hope to install the EPDM rubber roof on my tear by this weekend. The material I have is left over from a RV roof job, but you might find some scraps at a roofing co. that installs rubber roofs. A teardrop roof really doesn't require that much material.
I'm with Jeff on this one. This stuff is great. Its a sheet good and the only way it can leak is if you have a physical hole in it. Cheaper than Aluminum (if you can find certain aluminum widths), very forgiving, Goes on easy, if you goof up you can pull it up and do it over (as long as the glue is still wet,,,apx 1hr) No thin spots, a guarantee. You can buff it with Protect-all and it comes up "Shiny"
The stuff's around, you can get it here in small amounts, http://www.rvsurplussalvage.com/catalog ... ct_id=1883
and (for such a small amount) ask them to fold it (saves on shipping)....BUT open it as soon as you get it and roll it up.
But as others have stated, check with an RV dealer or roofer for scraps or left-overs.
I have years of experience with this stuff, as I'm sure Jeff has as well.
BTW I'm and Master Certified RV Tech too.
Happy Trails
Len
len19070
Images: 24
Postby Hoosier Greg » Thu Aug 14, 2008 5:27 pm
I am also going to use a comercial grade rubber roof on my build.
The benefits I see beside already mentioned is that I will not have to worry about road dings on the rubber.
Greg.
Hoosier Greg
Postby prohandyman » Thu Aug 14, 2008 6:43 pm
I used rubber roofing that is installed on RVs. Bought a remnant piece from a RV dealer, as well as the glue they use. Worked very well, and is paintable!
Dan
prohandyman
Images: 785
Postby Dragonryder » Fri Aug 15, 2008 6:55 am
I didn't know that you could paint it. I would like to match the rest of the camper. I've seen this type of roof in action. I guess I should specify what I'm talking about, the rubber roof. My sister lived in a trailer for a year and they put this stuff on a flat roof. They never had any problems with it. What type of paint can you use on it? I see that some of you have it in white. That wouldn't be so bad.
Thanks to all of you for the input. It never fails to amaze me how many ideas are out there. You are all very talented and I'm very excited to be a part of this forum. :applause: :thumbsup: :applause: :thumbsup:
Thank you and keep'em coming!!!
Signed, Me
Dragonryder
Images: 19
Postby mechmagcn » Fri Aug 15, 2008 11:27 am
Uh, correct me if I'm wrong, but I have seen very little that will stick to an EPDM rubber membrane. Another consideration, if any solvents are used, the membrane will fail, I have replaced several where folks have rolled on a topcoat of sealer the was solvent based and the membrane just fell apart.
If you use the EPDM, only use the suggested glue, a water based product, and I only use the Dicor lap sealant for any seams and to seal around trim.
The EPDM rubber membrane is some great stuff if used and cared for properly, but the application of the wrong cleaners or other chemicals can ruin it quickly.
I'm not trying to scare anyone away from this product, just giving a heads-up before mistakes are made.
Jeff & Micki
53 F100
mechmagcn
Images: 56
Postby Cliffmeister2000 » Fri Aug 15, 2008 11:33 am
mechmagcn wrote:Uh, correct me if I'm wrong, but I have seen very little that will stick to an EPDM rubber membrane. Another consideration, if any solvents are used, the membrane will fail, I have replaced several where folks have rolled on a topcoat of sealer the was solvent based and the membrane just fell apart.
I have also heard that this must be applied to un-treated and unsealed wood. In your experience, is this correct?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
