Wiring Harness Disconnect Between Hatch & Bulkhead?...
Anything electric, AC or DC
Postby Dean in Eureka, CA » Sat Aug 16, 2008 9:15 pm
I know several of you have done this and I like the idea too, would make removing the hatch a cinch, however...
After some digging around today at the places that were open I didn't find any suitable male/female connectors...
Whadya all use? :thinking:
I can get by with a four wire connector, but would like to find an eight wire connector, so I can put speakers in the hatch.
I would prefer something round, vs. flat, like a flat 4... Smaller the better.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby tinksdad » Sat Aug 16, 2008 10:02 pm
Amphenol plugs. They come in all configurations. You have to solder the pins yourself though...NO pigtails!!
tinksdad
Images: 155
Postby rainjer » Sat Aug 16, 2008 10:31 pm
This is what I used:
http://shop.easternmarine.com/index.cfm?fuseaction=catalog.prodInfo&productID=5180&categoryID=209
What about using 2, 4wire flat plugs?
Jeremy
rainjer
King Koleman
Images: 11
Postby jdarkoregon » Sat Aug 16, 2008 11:46 pm
I used a 4 wire Round, got it at schrunks or however you spell it, don't know the brand, that is for the trailer running lights, there there is a two wire flat for the 12 volt trailer lights
Good like, John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby madjack » Sun Aug 17, 2008 2:55 am
rainjer wrote:This is what I used:
Jeremy
...I used that same type connector...I think I picked it up at a local auto parts store................ 8)
Postby Sonetpro » Sun Aug 17, 2008 5:17 am
Batt's Racing has automotive connecters. Very good quality and priced well.
http://www.deutschconnector.com/index.html
Sonetpro
Images: 107
Postby toypusher » Sun Aug 17, 2008 9:09 am
I got mine at HD or Lowes (can't remember which). Don't have any pics off hand, but they are just single wire, round male and female matching plugs. They are insulated and I then just put some wire wrap over to make it look better.
toypusher
Images: 324
Postby jeep_bluetj » Sun Aug 17, 2008 1:42 pm
There's a zillion options for you -- look at autoparts houses, etc.
I generally use mini-molex connectors (available at radio shack) for this sort of application. Reasonably small, easy to assemble, and has a pretty good current rating.
digikey.com has tens of thousands of connectors to brows through.
http://order.waytekwire.com/CGI-BIN/LAN ... 31+M37+ENG has thousands
You _could_ use a trailer connector but they're pretty big. I'd use a smaller molex or amp-style connector.
-- Jeff --
jeep_bluetj
Postby Miriam C. » Sun Aug 17, 2008 7:12 pm
8) I used a normal trailer wire conector.
Postby boomboomtulum » Sun Aug 17, 2008 10:15 pm
This is all I did. Then I covered it with a small 1/8 ply. sheet w/ 4 small brass screws. cover is 5x13. I'm glad I put this in I have had to remove hatch once so far.
Click on the link below and in the bottom right corner of the hatch you'll see the small ply. cover.
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
Postby looped » Sun Aug 17, 2008 11:41 pm
boomboomtulum wrote:This is all I did. Then I covered it with a small 1/8 ply. sheet w/ 4 small brass screws. cover is 5x13. I'm glad I put this in I have had to remove hatch once so far.
where did you get the plug with the screw mount hole? im really digging that!
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby boomboomtulum » Mon Aug 18, 2008 11:34 am
Walmart I believe, during the build gathered all sorts of stuff but I think that is where I got it, or was it Tractor Supply Company? :thinking:
Dave
boomboomtulum
Images: 50
Postby G-force » Mon Aug 18, 2008 2:09 pm
How often do you plan on removing the hatch? I plan on just using a terminal strip for ring connectors. If I have to remove the hatch, just unscrew 4 or 6 screws, and never have to worry about it coming loose. Something like this:
http://www.jamestowndistributors.com/us ... +Hot+Feed+
Mike
G-force
Images: 22
Postby wlooper89 » Sat Aug 23, 2008 12:36 am
The Anderson Powerpole connectors work well. Easy to connect and disconnect. The wires can be soldered or crimped to the connectors. I like to solder them so they do not rattle or work loose. They make clean looking connections.
http://www.andersonpower.com/products/s ... rpole.html
Bill
wlooper89
Images: 75
Postby Dean in Eureka, CA » Sun Aug 24, 2008 3:37 pm
Sonetpro wrote:Batt's Racing has automotive connecters. Very good quality and priced well.
Thanks Steve,
That's just what I was looking for... :thumbsup:
Dean in Eureka, CA
The Fogcrawler
Images: 69
Return to Electrical Secrets
