mikeschn wrote:If you are eventually going to be using an AC, then you'll want to get the 2000 watt Honda. It can handle the starting surge of the AC....
You're not camping at a campground are you? The noise would be a real menace there.
mikeschn wrote:And the Honda 2000 will also recharge your battery at the same time. With the cheaper units, you'll have to furnish your own charger.
Sonetpro wrote:You cannot run a AC off an inverter. I tried.
_skydiver_ wrote:...I've seen several references to recharging batteries? Do generators or inverters have batteries in them? Right now my trailer does not have a battery of any kind. I just have one plug on the side of the trailer that is hooked into a power strip on the inside of the trailer...
Alphacarina wrote:Sonetpro wrote:You cannot run a AC off an inverter. I tried.
Sure you can - It's just not very practical to do it with a small travel trailer
You would need a 2,000 watt inverter and then a BIG battery
If your A/C uses say 7.5 amps of 120VAC, then the inverter powering it will use about 75 amps at 12 volts DC to do the same job. Want it to run overnight? 8 hours at 75 amps per hour is about 600 amp hours. Since it's not good to discharge your battery bank below 50% or so, you'll need a 1200 AH battery bank. They make such things, but one would weigh over half a ton . . . . then you'd need to figure out how to recharge it. With a 50 amp charger, it would take you most of the 16 hours you have before it's nightime again
Don
_skydiver_ wrote:Ok, so what is this then?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=360081523543&ssPageName=STRK:MEWA:IT&ih=023
Will that do both, will it run the small stuff as well as an AC unit? When I'm at the DZ, I don't mind letting it run while I'm using those items as most of the time I'm not even in the trailer and when I am, I want/need it cool and I want to watch TV or use my laptop. Does that item on eBay have a battery built in and it charges while the load it low or something?
Sorry for being so dense about this. Trying to learn though.
Sonetpro wrote:_skydiver_ wrote:Ok, so what is this then?
I would say that is probaly a chinese knock off. I have a Kipor 1000 that is also a chinese knock off. It was a great generator until I needed parts for it. It had a warranty but what good is a warranty unless there is a service center that will repair it. In my case the fuel petcock broke. It took me a year to find the $5 part.
During that year I bought a Honda and it is the main generator now. The Kipor is only used to run the fridge now in a power outage.
