Water Tank
Postby bdosborn » Fri Aug 22, 2008 9:08 pm
I used Andrews calculator to place my water tank (in the design library).
Then I hung it from the floor, close to the axle so the weight difference between empty and full would have less effect on the tongue weight. I used a pump to pull the water from the tank and send it to the faucet:
The pump automatically turns on when you open the faucet and turns off when you close it. I put a switch in the electrical feed so I can turn it off when I drain the tank, because running it dry will burn it out. The sprayer seemed like a good idea but it tends to splash water everywhere. I'm not putting one in the next trailer. The water inlet is just a collection of tubing and fittings I got from HD.
Images: 806
Postby CaptainKram » Mon Aug 25, 2008 11:13 am
Hi Bruce,
Really nice job on the water tank! :thumbsup: The placement looks perfect. :applause: You might want to put some sort of skid plating over the tank to protect it from any road hazards. You can probably find something off a junkyard jeep that would fit just fine. Take it from an old biker ;) , stuff kicked up at highway speeds can do some real damage!
CK
"A woman drove me to drink, and I didn't even have the decency to thank her." ~W. C. Feilds
CaptainKram
Images: 6
Postby bdosborn » Mon Aug 25, 2008 1:27 pm
The tank is higher than the axle so I won't scrape it off or anything. The plastic they use for the tank is amazingly tough, three years now and no problems.
Images: 806
Postby Lgboro » Mon Aug 25, 2008 4:18 pm
Bruce,
If you don't use your spray attachment you could replace it with a pump for dish detergent (manual pump), I think it fits the same size hole the sprayer does. Your sink set up and plumbing are first class.
Lgboro
Images: 53
Postby bdosborn » Mon Aug 25, 2008 10:48 pm
Thanks for the nice comments. Alas, the Go Devil has been sadly neglected lately as I've been working on the Box Car so much. I doubt I'll change much on it but thanks for the tip on the soap dispenser.
Images: 806
