Ivar the Red wrote:Well...since we're all here and on this subject, let me ask. Do I need 2X4's for a floor frame that hangs out past the trailer frame about 12 to 14 inches? If so, should they be upright, or flat?
starleen2 wrote:Ivar the Red wrote:Well...since we're all here and on this subject, let me ask. Do I need 2X4's for a floor frame that hangs out past the trailer frame about 12 to 14 inches? If so, should they be upright, or flat?
Johnny, mine overhangs about 14 inches past the trailer frame with no other support - I used 3/4 inch ply for the floor - no sag yet
Ivar the Red wrote:starleen2 wrote:Ivar the Red wrote:Well...since we're all here and on this subject, let me ask. Do I need 2X4's for a floor frame that hangs out past the trailer frame about 12 to 14 inches? If so, should they be upright, or flat?
Ok, Scott, I know you and Rich have looked at my build thread so, even with the extra length and more wall space, is it still feasible to go with out the frame?
MOKI SEAKER wrote:I needed the extra space for insulation, it gets a bit chilly up here in the winter, I was really thinking of standing the 2X4's on edge for even more space for the foam sheets. I have 3/4" ply on the bottom 1 1/2" of foam and 1/2' ply on top, mostly for to keep out the cold. Jim G
You need to rethink that. I've camped in the snow and cold (below freezing in Utah & Colorado) several times. Snug as a bug in a rug and no insulation underneath. But I also don't camp in Alaska so I can understand why Dave added insulation.jamesm wrote:Dito for me...granted it does not get cold here...but I like to camp in the snow. So I built it like that also...plus it was left over construction material I was given for free.MOKI SEAKER wrote:I needed the extra space for insulation, it gets a bit chilly up here in the winter, I was really thinking of standing the 2X4's on edge for even more space for the foam sheets. I have 3/4" ply on the bottom 1 1/2" of foam and 1/2' ply on top, mostly for to keep out the cold. Jim G
Gage wrote:You need to rethink that. I've camped in the snow and cold (below freezing in Utah & Colorado) several times. Snug as a bug in a rug and no insulation underneath. But I also don't camp in Alaska so I can understand why Dave added insulation.jamesm wrote:Dito for me...granted it does not get cold here...but I like to camp in the snow. So I built it like that also...plus it was left over construction material I was given for free.MOKI SEAKER wrote:I needed the extra space for insulation, it gets a bit chilly up here in the winter, I was really thinking of standing the 2X4's on edge for even more space for the foam sheets. I have 3/4" ply on the bottom 1 1/2" of foam and 1/2' ply on top, mostly for to keep out the cold. Jim GI do have insulation in my walls and roof for those extra cold nights. It also helps to keep the inside cool durning the hot summer.
So tell me Jamesm. Do you really have 1 1/2" of insulation in your floor?
Like I said, I think 2x4 framing is to much and really not needed for the average teardrop build. If I was to insulate my floor, I would start with a sheet of 1/4" birch, add 1/2" framing and insulation and another sheet of 1/4" birch. And if assembled correctly, would make for a strong light weight floor.
Arne wrote:I went with 1.5" wood/insul in the floor because I got rid of most of the x-members in the trailer... needed the 1.5" for bridge beam strength from one side rail to the other. 5' wide, no flex in the floor...
