by Dale M. » Wed Sep 10, 2008 12:03 pm
Padlocks on the lever that engage the latch for the ball are especially vulnerable.... Long handle bolt cutter can usually snap a "hardened" steel shackle on any average consumer lock. If some body want it bad enough you cant stop them........
But I store a (very desirable) "car carrier" flat bed trailer in a semi public place.... I use a lock assembly that BLOCKS the ball socket and I use large cable lock through the wheels.. So far its been there every time I needed it for 4 years now.....
Consider making it less desirable to steal by simply removing a wheel and chaining wheel to a tree, or some sort of "boot" that locks over a wheel so it cant roll. Some have even resorted to putting a receiver on tongue so "hitch" can be removed..... If wheels have holes in them you can run a long steel rod through one wheel, to other and put lock(s) into it keeping wheels from turning....
These are just ideas to inflame you paranoia..... (just kidding) but the more complicated you make it, the less chance it will be bothered... Thief are usually a crime of opportunity...
Dale
Dale M. on Wed Sep 10, 2008 12:04 pm, edited 1 time in total.
