I've looked at Austin Hwd and McMaster Carr and neither carry them anymore. Anyone have another supplier?
Gerdo wrote:Dean
That is exactly what I'm looking for. You da man!
Thanks
Gerdo wrote:BONNET?
Your car wears a BONNET?
Gerdo wrote:Just kidding.
I have a TR6 and yes it also has a bonnet.
I used these on my teardrop because I knew that they would work. My hatch is big and a little heavy. I also didn't like the thought of gas shocks constantly pushing on the mounting screws. I also didn't want to have to replace them when they can't hold the hatch open from age or cold. These are predictable. I just bought a pair to replace the gas struts on my pickup topper back window.
boomboomtulum wrote:This is exactly what I have been looking for as well. Now a Question. What method other than Trial & Screw -up is best for fitting? Where and how do you figure placement of these and length of supports?
Dave
Gerdo wrote:The way I figured which to buy and where to mount was simple. I marked, with tape, where I wanted the props to mount when opened and compaired the given sizes. I then closed the hatch to see if I was at the closed length or longer, longer is not bad. If not I moved my marks until the two worked. I wanted the mounting points out as far as possable.
