Vinyl Top
Vinyl Top
Postby ALAN GEDDES » Mon May 30, 2005 6:18 pm
I am considering a Vinyl top on next tear and was wondering what type of adhesive would be best. It would have to be water proof I would assume. Edges could be tacked or trimmed. Probably be laying it over a painted wood surface. Ideas/suggestions ?
Alan
ALAN GEDDES
Images: 34
Postby Chris C » Mon May 30, 2005 6:34 pm
I imagine you would get a lot of suggestions here on this site, but if I were you, I'd go to a seatcover shop near you and ask. You know, auto tops were vinyl covered for many years, and I guess some still are. They could tell you about adhesives which will last indefinately.
Chris :D
Chris C
Postby Cutterpup » Tue May 31, 2005 10:41 am
Vinyl tops are glued on with "Upholstery glue" i.e. plain ordinary contact cement sprayed on both surfaces and stretched onto place. Then all the edges are either tucked under or secured with trim moldings. However the tops only last between 3 and 5 years before they start to show their age.
Dan
Cutterpup
Images: 15
Postby SteveH » Tue May 31, 2005 12:49 pm
Allen,
Find an automotive upholstery supply place near you. They will have the vinyl, or in some cases fabric is used, padding, and the spray glue.
SteveH
SteveH
Images: 42
Postby john » Wed Jun 01, 2005 9:01 pm
Hi
I concure with Steve H who said go talk to a seat cover place. I knew a guy that did seats and vinyl roofs where part of the job.
I intend to cover my tear with some left over rubber roofing. That includes the hatch and hinge. Currently the tear is covered with bare hardboard. No paint yet. Any thoughts on glue? Sould there be paint on the roof? The change the type of glue used
This is not vinyl, but rubber.
john
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby Nitetimes » Thu Jun 02, 2005 12:26 am
john wrote:Hi
john
I used to do rubber roofs years....... ago. I know back then the only good glue for them was the contact cement that was made for that purpose. Things probably changed since then so there could be other useable products for them, but your best bet would be to talk to a rep from one of the rubber suppliers. I'm sure they would point you in the right direction.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Arne » Thu Jun 02, 2005 5:31 am
I'd check with automobile places that do vinyl roof applications. And perhaps marine suppliers of high end boats that use vinyl on sun decks....
3 to go......
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Chip » Fri Jun 03, 2005 5:00 am
Rubber roofing, Is it black or white,,, If black its gonna make the tear real hot by absorbing heat ,,, but if ya want to use any single ply roofing there are two types of glue made just for roofing,,, one is a solvent based contact cement,, the second is a latex adhesive,, both hold very good but the latex is a lot easier to work with,, both can be had in 1 or 5 gallon containers,, the gallons should cost ya about 25 to 30 dollars a gallon,,
I have TPO on my tear which is a white single ply,, so far its working real good,,
chip
54"x9'4" tear
4'x8' tear
Chip
Images: 49
Postby Arne » Fri Jun 03, 2005 6:07 am
Chip, can you keep it clean? I've found even with my uniflex 255 (the expoxy coating), I can not get it back to its 'pure white' color after several months in the elements. When I removed the shore power cover and saw the original white underneath, there was a very noticeable difference... the covered area looked pure as the driven snow, the rest of the tear was 'dirty' by comparison..... and washing doesn't help much..
Arne
Mr. Subject Line
Images: 96
Postby john » Wed Jun 15, 2005 5:47 pm
My rubber roof material is black. Do you know the name of the glue product or where it can be bought.
I know the black will be hot, but I am well insulated and have an over sized A/C.
I am not too sure i will go rubber. I may still fo aluminum,.
john
Penomeli ikibobo
john
john
Images: 261
Postby RAYVILLIAN » Wed Jun 15, 2005 6:13 pm
You could check out a local RV repair/dealer for the rubber roofing. The one down the road from me lists both the material and several kinds of glue in their catalog. I thought about the stuff till I looked at the price, not cheap.
Gary
111961Image
RAYVILLIAN
Images: 109
Re: Vinyl Top
Postby BobR » Thu Jun 16, 2005 5:59 am
ALAN GEDDES wrote:I am considering a Vinyl top on next tear and was wondering what type of adhesive would be best. It would have to be water proof I would assume. Edges could be tacked or trimmed. Probably be laying it over a painted wood surface. Ideas/suggestions ?
Alan,
Here are a couple of links to a site with some interesting fabrics at a reasonable price
http://americanhomeandhabitat.com/products/Safara_Tex_FST080.htm
http://americanhomeandhabitat.com/products/heat%20shield%20aluminized%20mylar%20insulating%20fabric%20FHI018.htm
Bob Richert
Parrish, FL
"Be glad of life because it gives you the chance to love and to work and to play and to look up at the stars"
BobR
Postby IraRat » Thu Jun 16, 2005 9:00 am
Hey, Bob. That Safara Tex looks like a real viable option for some us. It's not very expensive, and it comes in a very generous width.
I just emailed them for some specifics, like how to adhere and such. It doesn't look like it would bubble up or anything either...looks real thick.
I just wish it came in some other colors, and i wish i could SEE those colors on their site.
They sell a sample pack which includes the 4 available colors--plus a ton of other samples that we DON'T need. If they don't offer to send me just the Safara samples for free, I'll order the sample kit.
And Alan, after I look at it, I'll mail it to you so you can see if it's something you would want. I'm sure not going to buy anything without seeing the color in my hand, since I don't even know if I want to GO this route.
--Ira
IraRat
Forum Storyteller
Postby ALAN GEDDES » Thu Jun 16, 2005 9:07 am
Bob, Thanks for the material info.
Alan
ALAN GEDDES
Images: 34
Postby IraRat » Thu Jun 16, 2005 1:24 pm
Well, gee--I got the answer to my question about how to apply the stuff. I paste the entire e-mail here exactly as I received it:
"The safara tex would work. I do not know of wha tyou can use to put on the material. Thank you
Deanna S.
Sales & Service Rep
American Home & Habitat Inc.
1-866-458-2559
www.ahh.biz <http://www.ahh.biz> "
Doesn't inspire much confidence, huh? You ask how to apply it, and they don't know?
I just replied with my typical Brooklyn attitude requesting a clairification on why she couldn't tell me how to apply a product she's selling. And I was as nice as I could be...really.
FRIDAY UPDATE:
Well, she replied to my email, and here was her response:
"All I know aboutthe material is what is on our website. WE just sell the materail, we have never used anything to put on the back of the materail. I'm sorry that is all that I can can tell you. Thank you"
The typos, as before, are all hers--I just cut and pasted.
No wonder everything's being made in China today. As far as manufacturing goes, this country is in big trouble.
--Ira
IraRat
Forum Storyteller
