the jelly belly build
Postby del » Mon Sep 29, 2008 12:50 am
Covered up the insulation with 1/8 mahogany ply.
The clamp is the beginning of finishing the side wall of the galley. Hard to explain, so I will just show pics of the progress.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Tue Sep 30, 2008 12:24 am
I got to work on the jelly belly for a while. Added more insulation.
Added 1/8" ply. What a PITA working around the gas line.
Goodnight del
del
5000 Club
5000 Club
Images: 410
Postby dandan » Tue Sep 30, 2008 7:38 pm
Hi Del,
will keep you up to date with pictures. :thumbsup:
remember you are the first up the mountain, im only following in your footsteps.
i dropped Andy. G. an e-mail to ask if there was any copywright on his drawings, the reply was no & pointed me towards your build.
thinking of trying to do something like a time-laps series of images from the same angle & fill in with other more detailed images. probably wont work but its worth an attempt.
have aquired some clearance lights which were going to be used on jet-fighters wing-tips. they are ali, a nice teardrop shape & should fit in well.
anyway, its early days but ive costed the ali sheet to be £485 sterling including value added tax. (thats %17.5 the uk government adds to nearley all our retailed items as their little joke!)
Just wondering, have you been keeping tabs on the workshop hours spent on the Jelly-Belly build ?
Heres to the next project my poor wife has to suffer with. :cry:
All the best
Dan. :thumbsup: :thumbsup: :thumbsup:
Nostalgia's not what it used to be !!!
dandan
Roswell Club
Images: 214
Postby del » Tue Sep 30, 2008 10:38 pm
dandan wrote:Hi Del,
All the best
Time? Have not a clue how much time. But where ever I go it draws attention, so I hope you are not shy.
cheers del
A question though, are you going to make the original fenders?
del
5000 Club
5000 Club
Images: 410
Postby dandan » Wed Oct 01, 2008 9:14 am
Hi Del, :D
will be fitting the original fenders. Andy emaild a varient which is single curvature & alot easier to fabricate.
may resort to these if im getting too bogged down.
this means a loss of 2 foot potential extra width.
looks like i cant have my cake & eat it too !
:lol: :lol: :lol:
best rgds Dan.
dandan
Roswell Club
Images: 214
Postby del » Wed Oct 01, 2008 1:04 pm
dandan wrote:Hi Del, :D
:lol: :lol: :lol:
best rgds Dan.
Dan I can not wait to see how you build those fenders. When you are done put the extra 2 in a box, and send them across the pond :lol: only kidding.
good luck del
del
5000 Club
5000 Club
Images: 410
Postby del » Fri Oct 03, 2008 2:24 am
Got the top half of the hatch supports up.
The hatch likes to shift to the left on the hinge and has pulled itself free on one side. I must take the hatch off to reattach the hatch to the hinge.
I added more insulation inside.
I did call several insulation companies to see about spraying insulation in, but in the afternoon none of them wanted to answer their phone, except one that did not work with spray on insulation. :x :x
Still working on tidying up the galley walls, the opposite side no less.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Fri Oct 03, 2008 10:59 pm
It is raining here, but I took off the hatch any way. The screws holding the hinge to the hatch were failing. The first one was backing itself out, and became bent. The next two pulled through the hinge, and the forth one broke. The last two were doing fine. The problem is the hinge slides from side to side (it likes to go left for some reason I do not know), when it has shifted and you try to close it, it tries to pull off the hinge. :x In typical Merican style I changed to larger headed screws, and added 4 to each side.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sat Oct 04, 2008 10:53 pm
Back with more pics. Before I start I had to figure out a way to keep the hatch from sliding back and forth on the hinge, this is what I figured out. Trimmed off a little bit of the smaller hinge. Before.
After.
Here is what I trimmed off.
Now the when the hinge is reinstalled.
Pinched the ends with pliers.
The hatch now opens and closes normally, but am to scared to try and push it to the side.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Sun Oct 05, 2008 11:53 pm
Tried to hook up one hatch prop, failed miserably.
The hatch suport hits a piece of wood before it can extend fully and move the catch out. :x
Do I trim the offending wood, or add spacers to push the prop away from the wood?
del
del
5000 Club
5000 Club
Images: 410
Postby depatty » Tue Oct 07, 2008 1:00 pm
Del,
As the wood the prop is hitting doesn't appear to be structural/critical, trimming a bit off shouldn't hurt. Of course as light as that hatch is, it would be easier to try adding a piece as a spacer to see how it'll work instead of/before doing any cutting.
Dave
depatty
Images: 175
Postby del » Tue Oct 07, 2008 6:26 pm
depatty wrote:Del,
Dave
Hey Dave let me see if I can figure out how to trim that with out too much aggravation, I think you are right that is not structural.
Dave if I should end up in northern Alabama this winter should I wave?
del
del
5000 Club
5000 Club
Images: 410
Postby depatty » Tue Oct 07, 2008 9:17 pm
Del,
Cat says if you come through, wave, and don't stop for a visit, she'll throw a rock at ya! :lol:
Seriously though, if you do come through this part of the state, you're more than welcome to stop for a visit as well as spend a night or more. Just let me know about when.
Dave
depatty
Images: 175
Postby del » Tue Oct 07, 2008 11:44 pm
Hatch work today was canceled due to wind. I did work on the inside insulation (sorry no pics) and started to put on the clearance lights.
Spent more time figuring out how to install the first one, than I spent actually installing it. Go figure.
Dave tell Cat no rocks please, I will stop if I make it that way. I enjoyed my stay last year, thank you.
del
del
5000 Club
5000 Club
Images: 410
Postby del » Thu Oct 09, 2008 12:16 am
Got one more clearance light installed.
Now it is time to wire them.
del
del
5000 Club
5000 Club
Images: 410
Users browsing this forum: azgreg and 7 guests
