After trying to live with the standup camper I built last year and not liking the weight, way it towed, and needing to replace the skin, I decided to tear it down and start over.
One of the design perimeters is that it tow behind the Ranger pickup without me having to extend the mirrors. I got to looking at the size of the frame (76" wide and 118" long) and if I go to the edges of the sides it will be too wide. Got to looking at the way it was built and to make it narrower will mean rebuilding the entire thing and I don't really want to do that. Between the existing wheel wells (haven't got the floor removed yet) I've got 52" which just happens to be the width of the futon I am planning on using for our bed. So I got to thinking why not use the entire frame but make the camper body 52" inside with a 12" (or slightly less) running board/seating area on each side below the door and add a raised wheel well and behind that to the rear of the frame a storage box on each side. Back of the box will be a good tail light mount.
Am going to try to add pictures below of the plans I have worked out so far. Hope this works...
This first one is a base/floor layout:
And a side view. Other side will be a mirror image of this one. The running boards will be thin plywood or aluminum plate on top of the frame. Still working on how I'm gonna build the floor.
View from the front. Will most likely have a tongue box with spare tire mounted on front wall, just below the point it starts curving.
And last a view from the back showing the lights.
Still got a lot to work out before I start on this but it seems to be fitting together pretty well.
So, what do y'all think? Should I try this or cut the frame and rebuild it to fit the camper width?
