bledsoe3 wrote:The frame is done. All I need is the axle. I know from info on this site I need wheels before I can order my axle. It looks like 5X4.5 is the most common lug pattern. Is that a pretty standard pattern for wheels. I found some ford wheels (mags) fairly cheap, but it doesn't say on the wheels what the pattern is. Does anyone know if Ford uses 5X4.5 pattern?
bledsoe3 wrote:The frame is all done!For me at least, that was probably the easy part. I have posted pictures in my gallery. You experts let me know what you think. Be easy, it's my first time. http://www.mikenchell.com/forums/album_personal.php?user_id=1098
bledsoe3 wrote:I'm right around $510. $240 for axle/mounts and hitch, $175 in metal, $65 for used wheels and tires, $20 for swivel tongue jack and maybe $10 in hardware. Probably could have gotten away cheaper with a HF trailer, but I like this one better! Seems very solid, but not too heavy. I'm not sure of the weight, but I can lift the back with it hooked to the car.
