Sidewall contruction
Postby wantaTD » Thu Nov 27, 2008 12:53 pm
Has anyone ever contructed the sidewalls completed before permanently mounting them to the trailer floor. When I say completed I mean wired, insulated, finished inside and outsidewall attached. I've never built one yet, but this site got me :thinking: My thought is to build the 2 sides, front wall, galley wall and roof on the woodbench in the basement. Finish it and assemble in the driveway it the spring
wantaTD
Re: Sidewall contruction
Postby halfdome, Danny » Thu Nov 27, 2008 1:13 pm
wantaTD wrote:Has anyone ever contructed the sidewalls completed before permanently mounting them to the trailer floor. When I say completed I mean wired, insulated, finished inside and outsidewall attached. I've never built one yet, but this site got me :thinking: My thought is to build the 2 sides, front wall, galley wall and roof on the woodbench in the basement. Finish it and assemble in the driveway it the spring
Welcome to the forum wantaTD. I'm sure you could come up with some pre-fabrication but to include the exterior application whether it be aluminum skins, etc you would need to provide cleats to screw to. I make up my walls and then glue & screw the walls to the floor, bulkheads and spars. I wire the chassis separate from the teardrop assembly and wire it after it's assembled. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Esteban » Thu Nov 27, 2008 9:07 pm
Welcome wantaTD to the play land of teardrop builders.
:thumbsup: Steve Frederick has an "inside out" system for prefabricating and assembling the major tear drop trailer components that should meet your goals. He sells a CD that documents his method of building a tear drop. I have one. Printed it out as use it for a reference in my "shop." It's very helpful. Well worth buying. He recently updated it with more photos and information on hatch building.
Builders Shop Manual
On his website he documents the building of several trailers. If you look them over you'll get an insight into his ideas and building methods.
Steve - SLO, CA
Esteban
Images: 15
Postby Mauleskinner » Thu Nov 27, 2008 10:19 pm
I've got Steve's shop manual, and agree with Esteban...it's probably very close to what you're wanting to do.
David
Mauleskinner
Postby planovet » Thu Nov 27, 2008 11:25 pm
That's pretty much what I'm doing. The sides, the front bulkhead and rear bulkhead are finished and I'm working on the doors now. Once they are done, I will put it together. I hope it works!
ImageMark (& Cindi)
planovet
The Cat Man
Postby aggie79 » Fri Nov 28, 2008 6:24 pm
This is what I will be doing too. The exterior finish will be aluminum, and I have even thought about applying that before the teardrop is assembled.
outback
Postby greekspeedoman » Mon Dec 01, 2008 3:46 pm
Check out the outback teardrop website. This is exactly what they did with their trailer. The entire body was assembled and nearly finished when they installed the floor.
greekspeedoman
