sounds like size I was thinking about, 5x10 trailer (+ tongue) extend rear and front 1' each, slide out for chemical toilet or RV commode (slide out that entire side with galley or just the commode part of that side) idea I had already decided on (how much of a slide still up(, room for full shower a must for me - I'm hoping to take it to some out of the way places..... (losing oneself is a great feeling) pop up vent probably a must too for odors as well as dissipating moisture. gray water tank under shower, black water for commode? or simplify with chemical toilet.
6'5 or so interior head room preferably, galley opposite the bed, same side as shower, with 2 to 4 burner propane stove (vent above and/or window in front of it to vent heat) along with sink and some counter space. And maybe a microwave (hopefully, at least for when power hook up is possible) small rv refrigerator (12 volt or propane or for when power hook up is available) I have access to a Onan rv generator, but dont know if I can find space for it, possibly install it in Camper van and run power cord to towed camper
The bed (futon or other folding type bed to help save space when not in use) along one wall (I don't mind crawling over the wife or her crawling over me) if space allows possibly a swivel/reclining van seat
full sized door towards rear or in rear to one side, bed side of camper to allow room for shower on the other.
I think it will be classed as small travel trailer, as 12' plus tongue would put it bigger than what most would consider a TINY travel trailer. not that it matters.... Vans are 5' wide or a little better, height shouldnt be a problem, only a little taller than high top of astro and if nessesary a small air deflector can be attached to the Safari's luggage rack with out too much trouble
My tow vehicle will most likely be Astro (hopefully a small camper in itself) or Safari (work vehicle) both should have no problem hauling it.
I'll have to go back through thread and see if any shapes have been agreed to yet.
got a couple thoughts (probably too crazy, but you never know) after thanksgiving, I will have to pick up a book of graph paper and start thinking harder....
