Spar varnish
Spar varnish
Postby Chris D » Tue Dec 02, 2008 5:48 pm
Folks,
I have been in the carpenter for over 20 years And I just wanna say what happened to GOOD OLE SPAR VARNISH for exterior wood apps. I have used this countless times 2 coats thinned and 2 finish coats on fir mahogany teak cedar and I gotta say I have 0 problems. So I guess what I am getting at is thats the the way I am gonna do me side walls on THE DOWN JERSEY TIN TOP. I learned long ago NEW AND IMPROVED MEANS THEY SCREWED IT UP, ANYBODY WITH ME
Chris D
Postby len19070 » Tue Dec 02, 2008 7:01 pm
I'm with ya Chris.
I haven't looked in the Marine places yet but there was nothing like it.
Happy Trails
Len
len19070
Images: 24
Postby Steve_Cox » Tue Dec 02, 2008 7:21 pm
Image :thumbsup:
Steve_Cox
Images: 196
Postby 48Rob » Tue Dec 02, 2008 7:33 pm
Chris,
I'm with you on the quality material, but equal or greater importance must be placed on application technique (making sure that no part of the wood is left exposed!) :thumbsup:
It is always easier to do it right the first time, than to tear it apart to do it over...
:cry:
Rob
48Rob
I hear that
Postby Chris D » Tue Dec 02, 2008 7:42 pm
I figure you have tocoat all 6 sides of every piece of wood spars ply etc..... I think that is what your getting at right BOB
Chris D
Postby Arne » Tue Dec 02, 2008 9:52 pm
Don't forget the bottom of the ply.. that is where the water is likely to wick up.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby schaney » Tue Dec 02, 2008 9:55 pm
Hmmm, IMHO "New and Improved" usually means repackaging something that's been around for awhile to generate new interest in it.
From what I've seen the world of exterior finishes has been going through a lot of changes dealing with the requirements to reduce VOC (Volatile Organic Compounds). From this has come some interest new products. With many years of success using Epifanes Spar Varnish, I'm open to change, if it mets my criteria and needs.
Scott
Camping the "Compact Way"
schaney
Images: 262
Re: Spar varnish
Postby starleen2 » Tue Dec 02, 2008 10:00 pm
Chris D wrote:Folks,
I guess we're back to vacuum tubes too!
starleen2
5th Teardrop Club
Postby Steve_Cox » Tue Dec 02, 2008 10:50 pm
schaney wrote:Hmmm, IMHO "New and Improved" usually means repackaging something that's been around for awhile to generate new interest in it.
Nice thing about Epifanes Spar Varnish is not having to sand between coats.
Steve_Cox
Images: 196
Re: Spar varnish
Postby Juneaudave » Wed Dec 03, 2008 12:12 am
:rofl: :rofl: :rofl: Come on Chris!!! Where's your sense of adventure????
Juneaudave
Images: 380
Postby bobhenry » Wed Dec 03, 2008 7:50 am
The luan on Chubby has and original 4 coats Of Marine Spar Varnish and a year later I sanded and applied 2 more. He sets outside in the rain , snow , and hot sun.
I coated only the face and have some lifting , however the lifting is the face layer of the luan itsself indicating to me that the moisture is entering from the back and lifted the top ply of the luan itsself. I also have some discoloration at the seams indicating moisture entered the edges. I thought the Spar Varnish would build up enough thickness to bridge the seams but apparently it did not. It will probably be sanded and body filled next summer and painted. I will miss the wood look but it will continue to deteriorate if steps are not taken. A wood teardrop is like a wooden boat they take a lot more attention and a sheltered storage place would be a BIG plus.
Postby schaney » Wed Dec 03, 2008 10:36 am
Steve, I'd have to check the spec sheets, but if I remember correctly "Rapid Coat" and "Wood Finish" don't require sanding, although "Clear Varnish" does.
Scott
schaney
Images: 262
Postby john » Wed Dec 03, 2008 8:30 pm
I tend to get accustomed to a particular product's methods and dislike change.
I'm not even old yet :thinking: :thinking:
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby Tripmaker » Thu Dec 04, 2008 1:34 pm
My brother swears by Simonize as the best car wax and has accumulated a lifetime supply. Not so sure I agee with him on that one. Newer products protect better, last longer, and most importantly are easier to apply.
But I used spar varnish on my TD. :lol:
Jim
Tripmaker
Images: 59
Postby Roly Nelson » Mon Dec 15, 2008 8:33 pm
Spar varnish and I are good friends. We meet once a year for 2 days.........sand, tack-rag and finish. Hey works for me, and I don't know anyone who is foolish enough to have more wood showing than I do. After 6 years, I guess that makes about 8 or 9 coats so far. No peeling or obvious leak areas that I have noticed.
So, chaulk down one vote for me on common ordinary spar varnish, 49 bucks a gallon at the big box stores. If I wasn't so cheap, I guess I would get it at a Marine store for twice as much. No wax on my varnish, I fear the next coat of varnish wouldn't stick in the areas where wax wasn't entirely removed.
Roly :R :thumbsup:
Roly Nelson
L'il Ol' Woody Builder
