wlooper89 wrote:...
My Little Guy has a 72" wide frame but the wheels and fenders stick out about 11" on each side, making it almost 8' wide at that point. Does the outside width of the wheel base need to be included in overall width if that is wider than the trailer frame?
The trailer is built with front and rear clearance lights mounted on the fenders, but no center rear identification lamps. From the chart it appears the center rear lights, area 7, would be required if the outside wheelbase of my trailer is counted as part of the width.
But then I would be surprised if Little Guy is building trailers that lack required lights.
Bill
It may be that the "width" is only of the main body, and excludes wheels and the fenders covering them. It may also be that the Little Guy is not compliant with the rules; with no offense intended to any manufacturer, it wouldn't be the first time that something was built and sold which did not follow the rules. In practice, as long as cops don't issue tickets, it's allowed.
It's also possible that each state's implementation of the federal rules varies, and the fenders count in some places and not others. Here in Alberta, the regulation does not say anything about what is or is not included in the width, except to say that the load carried on a trailer
is included. It would not make much sense to me if a trailer with a 72" wide deck needs wide-vehicle identification lights when it is carrying an 81" wide load, but
not when it is not carrying the load despite having a 94" overall width across the fenders. Good sense, of course, is optional in law.
In the Alberta rules, the associated section for clearance lights does specifically allow truck tractors to place the clearance lights to "indicate the width of the cab only", rather than the whole truck (which would include wheels and fenders much like a trailer)... but that doesn't exempt it from having wide-vehicle identification lights.
Again in our local rules here...
The identification lamps on a vehicle must be controlled by a circuit that is independent of the circuit that controls the headlamps and tail lamps of the vehicle.
and it says the same thing for the clearance lights.
Large commercial trucks do this, which is one reason they use a 7-pin connector just to run the trailer lights. Recreational trailers and small commerical stuff using electric brakes use the RV-style 7-pin connector, and (at least in any case I've seen, including my own factory-built trailers) the clearance and identification lights are just connected to the tail lamp circuit... so what is commonly built and sold does not necessarily comply with the rules.
By the way, FMVSS 108 and Canadian Motor Vehicle Safety Standards 108 are coordinated (essentially identical), so the U.S. and Canadian situations are comparable and Alberta works as an example of how local regs (state or provincial) interact with the federal (U.S. or Canadian) rules.
