schaney wrote:Yes, scarfing isn't just for the dinner table anymore![]()
The fancy way to make scarf joints is with something like a West Systems saw attachment
cuyeda wrote:Two questions.
Ok so the slot and spline method seems like a viable alternative to join sheets together. What minimum thickness can this method be applied? If you are using 3/4" it wouldn't be a problem, but what about 1/2", or 1/4" thickness.
When using the epoxy method to glue the joints together, is it just straight epoxy, with out the fiber cloth? Or, is the cloth used to wet out as a backing for strength?
Lou Park wrote:Why don't you just lap joint it? Cut a 2" strip, 3/8" deep on each
piece of 3/4" ply and glue together. That way if it tries to separate
in the future it won't leak.
lou
I'm lazy and look for the easiest way to do any job, that produces the wanted/acceptable result
cuyeda wrote:MJ,
Thanks for the reply. Next on the list of tools to acquire, spline cutters.
A router with a slot cutter bit can do both splines and biscuits.
