5x10 Plywood Source In The South NEEDED!
Postby madjack » Tue Jan 13, 2009 10:02 am
TK, while I certainly admire a well done scarf joint(like Shaney's are), a properly done scarf joint is twice the angle that a skil or table saw can cut, which can mean quite a bit of hand work, to get a properly prepared joint...which is why I opt for the easier slot and spline method...it is easier and gives a mechanical aspect to the join and with epoxy is pretty darn effective...like any good adhesive, the wood will fail before the glue joint does...just another option to consider...........
madjack 8)
Postby planovet » Tue Jan 13, 2009 10:29 am
I couldn't find any 5x10 material either. And since my tear is 11' long at it's longest point, a single sheet would not have done anyway. So I used 5x5 material and used biscuits and glue to join them. I had never used biscuits before but it was easy and it turned out great. Yes, you will have seams but that's life!
ImageMark (& Cindi)
planovet
The Cat Man
Postby schaney » Tue Jan 13, 2009 1:04 pm
Yes Madjack, doing scarf joints by hand is a bit of work. The fixture West Systems has available holds your saw at a 7-8 degree angle to the plywood, making scarf joints a breeze.
I also agree, in a good joint, the surrounding wood will fail before the joint. As they say, "there is more than one way to skin a cat"
Scott
Camping the "Compact Way"
schaney
Images: 262
Postby TinKicker » Wed Jan 14, 2009 10:01 am
Okay...looks like I'll go with the slot and spline. I think that prepped properly the joint won't be visible anyway. My relunctance was more because of potential weakness in the joint than because of looks, but I guess the epoxy will more than take care of that.
Thanks guys for all the good input. :applause: :applause: :applause:
Kelsey
__________
Go ahead and get your project started because it's just like having kids...if you wait to start until you're skilled enough or rich enough, you'll never do it. And just look at what you'd miss!
__________
In planning any project you've never attempted before, always allow for the three three's: It will take you three times longer, three times more material, and three times more money than you thought.
TinKicker
Images: 11
Postby cuyeda » Thu Jan 15, 2009 6:09 pm
Two questions.
Ok so the slot and spline method seems like a viable alternative to join sheets together. What minimum thickness can this method be applied? If you are using 3/4" it wouldn't be a problem, but what about 1/2", or 1/4" thickness.
When using the epoxy method to glue the joints together, is it just straight epoxy, with out the fiber cloth? Or, is the cloth used to wet out as a backing for strength?
Cliff & Vanessa
cuyeda
Postby mikeschn » Thu Jan 15, 2009 7:56 pm
schaney wrote:Yes, scarfing isn't just for the dinner table anymore :picnic: :Flippin Burger: ;)
The fancy way to make scarf joints is with something like a West Systems saw attachment
That's an interesting looking attachment... unfortunately the thickest material it can scarf is 3/8".
This is a unique tool for cutting accurate scarf joints in plywood up to 3/8" thick. Attaches easily to most circular saws and is simple to remove. The West System 875 Scarffer was designed by Gougeon Brothers, so you know it's not only a quality and useful tool, but also tailor made for use in marine construction.
Postby madjack » Thu Jan 15, 2009 8:08 pm
cuyeda wrote:Two questions.
Cliff, you can use it for 3/4 or 1/2, I would be a bit leery of 1/4 which would be hard to join, what ever method you use except for a backing piece...I would do a 1/4" spline for 3/4" and no more than 3/16" for !/2"...depending upon application, cloth may or may not be needed...if a lot of structural strength is needed, a cloth backing would be the wya to go...if not, then no cloth would be needed...epoxy with the addition of a good filler would work for most application sby itself...on my last build, I made 9' panels in using this method and you could pick up the piece and shake the devil outta it an not get any flex...as in any such method of joining YMMV............
madjack 8)
p.s. for a spline, I prefer a hardwood cut on the crossgrain, with a 3/4" minimal width.........MJ
p.p.s. I have also cut a 45* angle with a skil saw and guide and slotted it for a spline...this makes a very stable joint but is PITA and since I am lazy, a butt joint with spline is MY preferred method........MJ
Postby cuyeda » Thu Jan 15, 2009 9:57 pm
MJ,
Thanks for the reply. Next on the list of tools to acquire, spline cutters. :thumbsup:
Cliff & Vanessa
cuyeda
Postby Lou Park » Thu Jan 15, 2009 10:02 pm
Why don't you just lap joint it? Cut a 2" strip, 3/8" deep on each
piece of 3/4" ply and glue together. That way if it tries to separate
in the future it won't leak.
lou
Lou Park
Images: 5
Postby madjack » Thu Jan 15, 2009 11:05 pm
Lou Park wrote:Why don't you just lap joint it? Cut a 2" strip, 3/8" deep on each
lou
Lou, that will work as well...keep in mind, 3/4" ply(or 1/2", or???) is not exactly that width but a 32nd(orso) smaller...there is also the fact of more material to remove, making more work to get a tight joint...as I stated, I'm lazy and look for the easiest way to do any job, that produces the wanted/acceptable result
madjack 8)
Postby TinKicker » Thu Jan 15, 2009 11:41 pm
You know, when my boss catches us doing something like that, he always blurts out, "Least line of resistance!" in disgust. He's about two hundred and eighty years old and mean-spirited. Funny thing is, when he does something like that, he calls it working smart.
I've always worked this way, and I really don't think it's being lazy. I think it's kind of dumb to do something the hard way and waste your time and energy when equally effective ways exist that make it easier/faster.
That's the limit of my thread-jacking. (Imagine that! Hijacking my own thread!) But these things just kind of pop into my wee little brain from time to time. :?
But it's another reason I'll use the slot and spline...working smart. :lol:
Kelsey
__________
__________
TinKicker
Images: 11
Postby madjack » Thu Jan 15, 2009 11:48 pm
Kelsey, I refer to it as "being efficient" :D ;) :lol: .............................................. 8)
Postby aggie79 » Fri Jan 16, 2009 9:15 am
cuyeda wrote:MJ,
I have a P-C biscuit joiner but not sure I would purchase one again due to its cost and limited versatility. A router with a slot cutter bit can do both splines and biscuits.
Postby TinKicker » Fri Jan 16, 2009 1:38 pm
I started to ask how the router could make the nice tapered oval biscuit holes, but then I realized...that doesn't really matter, does it? :? A slot's a slot.
I had a nice Craftsman router many moons ago and sold it for some reason. :cry: Gotta' buy another one now.
Kelsey
__________
__________
TinKicker
Images: 11
Postby mikeschn » Fri Jan 16, 2009 8:17 pm
I have a biscuit cutter. If you are going to do any woodworking, besides building your trailer, it's a good tool to have.
