Moderator: Sonetpro
bigalpha wrote:Make sure your rear suspension is in really good shape. Ford's rear springs were known to break causing serious droopage. Add a trailer to that and you've either 1. Hit the bumpstops or 2. ripped off your axle.
bigalpha wrote:The idea I was trying to get across is that you would be putting a lot of extra strain and stress on your drivetrain, especially for an underpowered car that's not really made for towing. You start pushing that baby up a hill and you'll strain that drivetrain even more. At any rate, it's just a thought.
bigalpha wrote:If you were a good fabricator, you could always add another wheel at the tongue of the trailer. Similar to the extra tires big dump trucks have to keep the frame from bending all the way to the road.
brian_bp wrote:bigalpha wrote:The idea I was trying to get across is that you would be putting a lot of extra strain and stress on your drivetrain, especially for an underpowered car that's not really made for towing. You start pushing that baby up a hill and you'll strain that drivetrain even more. At any rate, it's just a thought.
I agree, adding a bunch of load works the drivetrain harder, which is why those towing limits exist. To be fair to the Escort, Ford does say "1000 lb" in the Escort manual, not (as many do) "do not tow". Even though my Focus and Terry & Lisa's have a different engine and transmission from Bob's car, the base or earlier Focus has the same engine/transmission as the 1997 Escort, and there shouldn't be a huge difference in durability.bigalpha wrote:If you were a good fabricator, you could always add another wheel at the tongue of the trailer. Similar to the extra tires big dump trucks have to keep the frame from bending all the way to the road.
Those extra tires on big dump trucks are on beam axles, like the tag axle of buses and big motorhomes, and I don't believe that they are there for the sake of the frame; they are there to meet legal limitations on the weight which can be carried on each tire or axle to limit road damage. They don't use them unless they have to; the buses and motorhomes only have them if the rear axle would have insufficient capcity by itself. The wheels on an extended frame behind a cement mixer are the same idea.
Those axles are as close as possible to the main axle and are in a very different situation dynamically than something right under the hitch. Adding a caster wheel under the tongue is a bad plan for control, and if the purpose is to reduce hitch weight then it makes more sense to just balance the trailer properly.
My example used 100 lb of hitch weight; I hope that's the outside limit and the design target would be lower, but even that 100 lb should not be a problem for an Escort to support, any more than the car would have a problem with 120 lb in the middle of the trunk.
bigalpha wrote:bigalpha wrote:If you were a good fabricator, you could always add another wheel at the tongue of the trailer. Similar to the extra tires big dump trucks have to keep the frame from bending all the way to the road.
brian_bp wrote:Those extra tires on big dump trucks are on beam axles, like the tag axle of buses and big motorhomes, and I don't believe that they are there for the sake of the frame; they are there to meet legal limitations on the weight which can be carried on each tire or axle to limit road damage. They don't use them unless they have to; the buses and motorhomes only have them if the rear axle would have insufficient capcity by itself. The wheels on an extended frame behind a cement mixer are the same idea.
I'm not sure if dumptruck specs vary across the region, but that extra set of wheels on the ones around here only contact the road as the rig is loaded and the frame bends. I'm sure it helps with DOT regs, but It's there primarily to keep the frame from becoming a taco.
bigalpha wrote:... Instead of mounting a whole 'nother axle underneath the rear, why not just one tire that would pivot and turn with the car?
bigalpha wrote:Yeah, that's pretty much what the trucks here look like. However, whenever that axle is on the ground, the frame of the truck is noticably bowed downwards...
