bobhenry wrote:use close cell foam board its a lot easier and quicker
bigalpha wrote:Oh, gotcha. So that foam board/insulation will provide a great deal of rigidity; I can minimize the amount of framing I'd need in the walls.
I'm still torn on what size framing to use.
bigalpha wrote:I keep hearing that it's a matter of preference. I guess what I'm trying to get at is what's the 'industry standard'?
For example, when building a house, you use 2x4 framing 16" apart.
When building a TT that's 5' wide, 8' long and 6' high; is there a particular 'industry standard' that keeps the TT stable but lightweight?
After reading through various build threads, I see some with 1x2's and 1x4's and the bracing isn't very abundant.
bigalpha wrote:
I think that framing a subfloor is probably a little overkill too.
