Hey dropped floor builders....
Postby doug hodder » Fri Jan 23, 2009 3:49 pm
I'm still in a pencil cad mode and was wondering, what all you dropped floor builders have for ground clearance to the lowest point on your dropped portion when level. Any help? Thanks in advance. Doug
Postby steve wolverton » Fri Jan 23, 2009 4:06 pm
6".
�veni, vidi, vici.�
steve wolverton
Images: 11
Postby mikeschn » Fri Jan 23, 2009 5:33 pm
My dropped floor was about 8" from the ground. I don't think I'd go much lower than that.
Postby Steve_Cox » Fri Jan 23, 2009 10:14 pm
8" road clearance drop floor in front of the axle, no drop behind it.
Steve_Cox
Images: 196
Postby shopfabricator » Fri Jan 23, 2009 10:35 pm
8&1/2"
Guess I need to clean the lens.
How did the midnight b-ball game turn out?
Gary
...materials can no longer be purchaced at quite those prices mentioned here!
shopfabricator
Images: 138
Postby dhazard » Fri Jan 23, 2009 10:51 pm
Hi Doug,
I like the low look. I am at about 6".
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby shopfabricator » Fri Jan 23, 2009 11:10 pm
Another thought....
The drop is in Front of the axle.
My "pencil cad" for the next build wants the drop behind the axle. That's the Rub.
Current build has side skirts at 9&3/4" to 10" clearance at the tail depending on what is in the bed of the tow truck.
I drove down a drive that had gouge marks from other "low" trailers and just cleared. Scared Me!
This is a challenging build!
shopfabricator
Images: 138
Postby doug hodder » Sat Jan 24, 2009 12:09 am
I always try to hit those on an angle when I see all the scrapes in them. Thanks for all the measurements guys! Doug
Postby len19070 » Sat Jan 24, 2009 6:05 am
The Scotty I'm working on was 6" off the ground. I changed the axle and now its about 7 1/2".
There is an angle iron around the front of the box and it looks like it had been hit a few times.
Happy Trails
Len
len19070
Images: 24
Postby doug hodder » Sat Jan 24, 2009 7:44 am
Len, I looked at Steve E's Scotty the other day and it appears that the flat strap on the front of the dropdown is more of a skid bar than a structural thing, the structure is mostly in the gusset, definitely a good thing to incorporate into the frame. Doug
Postby Hector » Sat Jan 24, 2009 8:09 am
my drop down box is 8" from the ground. I measured a few vehicles some at the lowest point of the rear end and some at the frame rail and none were more than 8".although I have not put my trailer on the road yet I feel ok with that
Hector
Images: 46
Postby Steve_Cox » Sat Jan 24, 2009 9:51 am
doug hodder wrote:Len, I looked at Steve E's Scotty the other day and it appears that the flat strap on the front of the dropdown is more of a skid bar than a structural thing, the structure is mostly in the gusset, definitely a good thing to incorporate into the frame. Doug
At some point I dropped the ball on the front "dropdown". It was in the original plan but I ran outta bed frame angle iron and moved on.
Steve_Cox
Images: 196
Re: Hey dropped floor builders....
Postby aggie79 » Sat Jan 24, 2009 12:31 pm
doug hodder wrote:I'm still in a pencil cad mode and was wondering, what all you dropped floor builders have for ground clearance to the lowest point on your dropped portion when level. Any help? Thanks in advance. Doug
Thanks for posting this. I was just to this decision point in my build. :?
Postby jdarkoregon » Tue Jan 27, 2009 9:59 pm
I followed the height estabilished by the axle. 8 inches worked for my dropdown in-front, Behind and inbetween my axles
John
Innovation is essential
The world can be better
jdarkoregon
Images: 47
Postby Dean in Eureka, CA » Tue Jan 27, 2009 11:12 pm
Doug,
8" on "Gussets 101", with a skid plate gusset when I get back on that build someday.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Users browsing this forum: Google [Bot] and 6 guests
