Frog wrote:I'm curious as to why the HF trailers are used so much? It seems that with the amount of work and craftsmenship and the elapsed time to build these great trailers and the cost it would make more sense to get a slightly better built, stronger, American made trailer that uses 15" wheels.
HF trailers are used because:
1.) Nothing comes close to the price - I bought the most expensive and heavy duty one they sell (rated at 1,740 pounds) for $255
2.) They bolt together so guys who can't weld can build one
3.) They bolt together, so they come in a small box and can be shipped anywhere in the country for a few bucks - Handy for folks who don't live next door to a place that sells 'American Made' trailers
4.) They are both lightweight (great for buillding a lightweight teardrop as many are pulled by small 4 cylinder cars) and yet they are more than heavy duty enough for the purpose
5.) Because the bolt together, they're much easier to modify than buying an already welded up trailer which would require hacking up and rewelding
6.) Because literally hundreds (maybe even thousands) of others have built on them and very few have had problems because of the quality or design of the trailer . . . . otherwise they would have a bad name and nobody would touch one with a ten foot pole
7.) Did I mention they're
cheap - It's not just a few bucks cheaper either
8.) All of the above makes them an excellent choice to build a lightweight tear on
The cost would be a few hundred dollars more with not much of a weight penalty. The results would be a stronger trailer with more ground clearance with greater GVW and axle capacity as well as a better choice for larger diameter and wider American made tires for a better ride. The difference in weight of maybe 200 lbs would be hardly noticed by the vast majority of vehicles towing teardrops. The additional cost of a few hundreds amortized over the life of the trailer when several thousand dollars may be spent anyway would also seem to be money well spent.
200 extra pounds is a
ton when it comes to pulling with a small car, especially when it's wasted weight making something twice or three times as strong as it needs to be. Trailers ride best and work best when the weight of the trailer is about matched to the capacity of the axle - Building a 1200 pound teardrop on a 2500 or 3500 pound axle isn't really a great idea and most pre-built trailers which come with 15 inch wheels also come with axles designed for more weight than a teardrop . . . . so they ride WORSE than their HF counterparts - It's easier (and cheaper) to put 15 inch wheels on a HF trailer (if you really need them for some reason) than to work with a 3500 pound axle. You don't really want or need greater ground clearance . . . . again, if you're pulling with a small car, you want LESS ground clearance and you just about need a dropped axle if you want to use 15 inch wheels and tires. The real 'sweet spot' is probably13 inch wheels with 80 series tires designed specifically for trailers - That's what I've got on my HF 1740 trailer
Generally though, it boils down to saving a few hundred dollars and saving a few hundred pounds and sticking with something that isn't too heavy duty for what you want to build. When starting your teardrop project, think LIGHT and try to make it as LIGHT as you possibly can - Unfortunately when you're done, it will still be much heavier than it needed to be and you will pay for that extra, unnecessary weight in reduced gas mileage every time you use it
Don
