information pulled from a epoxy site.
Different amounts of resin are required to wet out different forms of fiberglass. For example, one gallon of resin will wet out approximately the following amounts of fiberglass:
40 square foot of 8 to 10 oz. cloth
50 square foot of ¾ oz. mat
30 square foot of 1½ oz. mat
35 square foot of 24 oz roving
In the event successive layers of glass are laid up before previous layers gelled, coverage will be greater.
The percentage of glass to resin in various laminates is:
Type of Fiberglass %Glass %Resin
Chopped Glass Lay-Up 25 75
Mat Lay-Up 30 70
Woven Roving Lay-Up 40 60
Cloth Laminate 45 55
The weight of a finished fiberglass and resin laminate is approximately:
Thickness Weight
1/4" 2 lb.
1/8" 1 lb.
1/16" 1/2 lb.
The above figures will vary depending upon the worker, thickness of laminate, and method used. In general, the higher the percentage of glass, the stronger the laminate.
