Any or all suggestions will be helpful.
I have put pictures on the bottom pictures on the build journal.
http://www.flickr.com/photos/twisted76017/sets/138594/
Thanks,
KZ76017
KZ76017 wrote:I'm almost done with my Teardrop and I need to know what people are using to cover any gap they may have between the top of the hatch and the top of the teardrop. I need to cover a 2" gap so I will probably need it to be at least 4" wide and about 72" long so I can lap it over the sides. and it will have to be flexible of course!
Thanks,
KZ76017
KZ76017 wrote:These are the finished pictures:
http://www.flickr.com/photos/twisted76017/34715628/in/set-138594/
http://www.flickr.com/photos/twisted76017/34715630/in/set-138594/
You are correct when you say
"you could use a strip of rubber or a similar material either under the hinge or over it to seal it from water leaks."
I need to find the rubber products to place over it and I'm wondering if any one else has any ideas of where to get it!
