doug hodder wrote:You might want to pull the cotter pin, back the castle nut off 1 notch and put it back in. Just might be that you have them up tighter than they need to be. You want to snug them up so that you don't get any play in the bearings, but not too tight that it restricts the roll. Some higher viscosity greases will be stiffer however. Did you put some new bearings in? Doug
bobhenry wrote:The "overheating " can be triggered by mixing different types of greases.
Not brands but types of grease ! There are many families of grease and combinations of some with others will destroy the grease and it will simply run out as oil and leave an under lubricated bearing to heat up. When repacking bearing clean all surfaces thoroughly. Solvent rinse and air dry but please don't spin te bearing with compressed air I have seen them handgrenade it can be dangerous.
