First sketches
First sketches
Postby BigE » Tue Mar 24, 2009 8:34 am
Ok so here is what I've got so far.
As you might see, this design is based off of Joann's awesome "Desert Dawg" design.
Some modifications though. It has to be tall enough to squeeze in a bunk for two children to crawl up on. Also, there is no need for a hatch as we've got other plans for the galley area.
Any ideas and thoughts for the dimensions would be greatly appreciated.
BigE
Postby stomperxj » Tue Mar 24, 2009 10:16 am
The way you have it drawn it looks a little short if you're only going 8' long. Doesnt leave much room for a bunk. What are the dimensions of the tongue box?
stomperxj
Postby stomperxj » Tue Mar 24, 2009 10:27 am
Alright so i whipped it up in CAD really quick. You should go get some graph paper and try to draw it to scale. The proportions are a little off. I traced right over the top of your picture and here are your dimensions:
2'-10" is a little short for the interior height. Those tires are 24" tall with 14" wheels
stomperxj
Postby BigE » Tue Mar 24, 2009 12:20 pm
Thanks, I was needing the help with the dimensions the most. That front part isn't a tongue box, it's all apart of the cabin. How high would you suggest in order to allow a bunk?
BigE
Postby stomperxj » Tue Mar 24, 2009 2:35 pm
Here's my take on that shape. I can send you a PDF you can print out if you want. Thats a 6" grid i put on it for you...
Let me know-
Jess
stomperxj
Postby BigE » Tue Mar 24, 2009 2:41 pm
That is awesome! Thank you for doing that. I would love it in pdf form.
BigE
Postby Miriam C. » Tue Mar 24, 2009 10:29 pm
:thumbsup: You took a lot of trouble with the design and it is cool. The only issue I see is the join from the front box to the top. I can see it being a leaky spot if not done carefully. Also you loose the extra space. If it is ascetics then cool.
As to the bunk for the kids, without a galley it should work fine. You won't have cabinets either though. You could always stretch it to 10' and 5' high if the space were needed.
You might mock it up with some cardboard. The best kind of CAD. 8)
Postby BigE » Tue Mar 24, 2009 10:39 pm
Thanks Miriam! I went out a minute ago and got some graph paper and worked some things up. My end result was 5 high, 5 wide and 10 long. I wasn't really going for looks as much as I was trying to cut some of the wind drag. :lol:
BigE
Postby BigE » Tue Mar 24, 2009 11:05 pm
Ok, I think I've got my graphics program setup to get me a more proportional view of things.
BigE
