HF TRAILER - Other Bearings
H.F. Wheel Bearing
Postby Cmdr » Wed Apr 01, 2009 10:58 pm
ArtFD,
Here is a replacement kit fore the H.F. 5x8 trailer...Check it out if you want. www.trailerpartsdepot.com Item # 81111 :)
Cmdr
Cmdr
Postby bobhenry » Thu Apr 02, 2009 7:37 am
It just ain't that tuff boys!!!
I trashed a hub ( some dumb butt forgot to tighten the lug nuts) .It expired almost right in front of a mom and pop farm store. I sat the hub on the counter the clerk reached on a shelf almost directly behind him and handed me the hub and seal and bearing kit with dust cover total cost $28.00. Any good farm store will have them ! This was NOT a bearing failure it was a case of stupidity that chewed the lugs off of the hub and trashed a rim.
Wheel Bearings
Postby Cmdr » Thu Apr 02, 2009 8:14 am
:thumbsup: Well there you go!!! Leave it to the plow boys to figure it out... :thumbsup: :thumbsup: LOL
Cmdr
Postby artfd » Thu Apr 23, 2009 10:21 am
I checked the trailerpartsdepot web site for wheel bearings & found everything listed there is SAE, not metric. The Harbor Freight bearings are metric. Are they interchangeable?
artfd
HF Wheel Bearings
Postby Cmdr » Thu Apr 23, 2009 7:37 pm
ARTFD,
For my H.F. 5x8 trailer the Item # 81111 at www.trailerpartsdepot.com fit my wheels.....I used a micrometer and got an exact fit before I put it together...After I got the measurements I had to do some conversion from metric to SAE measurement....Hope that helps
Cmdr :)
Cmdr
Postby artfd » Fri Apr 24, 2009 6:05 pm
artfd
ARTFD
Postby Cmdr » Sat Apr 25, 2009 6:17 pm
To make it real simple all you had to do is type in the number 81111 in the search window of the web page for www.trailerpartsdepot.com and it would have come up......Now what I'm saying is that for "MY H.F. 5' x 8' trailer that kit fit.....However I bought mine towards the winter of 2008....IF Harbor Freight DID NOT CHANGE ANYTHING IN THE MEAN TIME THEN YOU ARE IN LIKE FLYNN......
You can also buy a micrometer at Home Depot or Lowes for about $10. Do the measurement yourself.......OR take old parts into an RV Trailer supply house and they will match it up for you....
Cmdr :)
Cmdr
Postby Senior Ninja » Fri May 01, 2009 11:08 am
At the risk of repeating myself. We used a "Squeeze Ez" to grease all four of the bearings on the HF Trailer before putting it on the road. In preparation for moving the trailer back North, we checked the bearings planning to repack them. One of the inner bearings fell apart in my hand when we pushed it out of the race. We took the bearing to three different places before finding the exact replacement made by TIMKEN. The part numbers were the same. Our move North was close to three hundred miles. The three times we stopped I checked the bearing caps. They were stone cold every time.
Building the TD was the best thing I ever made.
Senior Ninja
HF Bearings
Postby Cmdr » Fri May 01, 2009 9:46 pm
Senior Ninja,
Well there you have it....Timken bearings are top of the line........ :)
Cmdr
Postby Senior Ninja » Sat May 02, 2009 6:46 pm
Cmdr has it correct.
My HF bearings were numbered 30205 just like the TIMKEN bearings 30205.
Senior Ninja
Postby Senior Ninja » Sat May 02, 2009 6:47 pm
Senior Ninja
Postby whitefishpoint » Fri May 20, 2011 5:36 pm
:( Well I took a blind gamble and lost.
For future reference:
The #81111 Bearing kit is NOT the correct bearing set for the Harbor Freight Model 93747 5'x 8'Trailer.
If you have the Model 93747 HF Trailer DO NOT buy this Bearing set (#81111). Its NOT the right bearing.
After taking out my bearings they are stamped with 30205 and the manufacturer is ZYX
http://www.zxy.com.cn/english/products/cpyf.asp
http://www.mcmaster.com/#catalog/117/1136 At the bottom.
Shaft diameter=25mm, OD=52mm, Width=16.25mm
whitefishpoint
Users browsing this forum: Google [Bot] and 0 guests
