Wheel size? & Glass fender question
Postby john » Mon Aug 29, 2005 3:18 am
It's funny. I just loged on to ask if wax paper would work as a release agent seeing as how I'am familiar with it in model construction. So thanks RKH for that .02 cents. Also a big thanks to all else for all the info. I am off to Autozone in the morning.
thanks guys
john
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby john » Fri Nov 04, 2005 7:55 pm
I thought I would show the results of all of your input.
The problem:
http://pg.photos.yahoo.com/ph/johngwalk ... pg&.src=ph
The form with wax paper before glassing:
The aluminum form and wax paper removed from outside and inside of fender:
The bondo:
After wet sanding the primer: (I wish I could keep the shine)
The paint, which looks better than the photo suggests:
Thanks for the help guys. You made the difference between a job I would have had to tolerate and a job I can be proud of and I'm proud.
:) :thumbsup:
P.S. This is what the board is for.
Penomeli ikibobo
john
john
Images: 261
Postby purplepickup » Fri Nov 04, 2005 8:20 pm
You have every right to be proud of that job John. The finished fenders look very nice. Nice set of pictures too. :thumbsup:
George
purplepickup
Postby madjack » Fri Nov 04, 2005 8:28 pm
...really nice John, I am glad this board could help you in the manner it was intended for
madjack 8)
Postby Chris C » Fri Nov 04, 2005 9:25 pm
WOW! Your pix look great. But based on your comment about the last pictures, you have a way to go. Here is a link I found which might be helpful to you: http://case-mods.linear1.org/case-mod-1 ... se-part-1/
Chris :D
Chris C
Postby john » Fri Nov 04, 2005 9:39 pm
I'll start tomorrow on those final (clear coat/buff) steps in that computer link.
Thanks Chris
Penomeli ikibobo
john
john
Images: 261
Postby doug hodder » Sat Nov 05, 2005 12:33 am
Good job guy....it appears that you solved all your fender issues...they look great!!! Hope I didn't mislead you....doug :thumbsup:
Postby bledsoe3 » Sat Nov 05, 2005 12:54 am
Those look great! I'm not sure I would have tried it myself, but you made it look easy. :thumbsup:
bledsoe3
Images: 112
Postby john » Sat Nov 05, 2005 1:36 am
No you didn't mislead. You don't know me so you covered all the bases and I hit only those that I felt applied.
Infact, my next father/son project will be a boat. Inspiration....Doug Hodder. (nothing fancy, just a small electric kayak thingy)
Penomeli ikibobo
john
john
Images: 261
Postby doug hodder » Sat Nov 05, 2005 1:42 am
I think you'll find that a boat is also an incredibly rewarding project...great family fodder...and the neighbors will go crazy!!! What Now!!! :o ....good luck and keep us all posted on your projects....especially the tear... :thumbsup: .Doug
Postby SteveH » Sun Nov 06, 2005 8:47 pm
Great work on those fenders, John! :thumbsup:
SteveH
SteveH
Images: 42
Postby john » Wed Nov 09, 2005 5:02 pm
The final step thanks to Chris C and his link.
I followed the instructions and sprayed 3 layers of clear coat, sanded with 2000 grit and finally buffed the remaining haze out.
Very little haze in the reflection. Pics:
Thanks Chris C.
Penomeli ikibobo
john
john
Images: 261
Postby toypusher » Wed Nov 09, 2005 5:06 pm
:o WOW! They are beautiful! :thumbsup:
toypusher
Images: 324
Postby asianflava » Wed Nov 09, 2005 5:10 pm
Good Job John! :applause: Just think, you didn't know how to do it when you started. Now you are a seasoned pro. :thumbsup:
asianflava
Postby madjack » Wed Nov 09, 2005 5:11 pm
...mans, WOTTA SHINE :thumbsup: :applause: :thumbsup: :applause:
madjack 8)
