How to build a door?
Postby tom_germany » Tue Apr 07, 2009 12:24 pm
hello everybody!
i have to set up my door, but i dont know how to do that.
maybe someone could help me out on that.
photos would be great, what do i need, how do i get it right.
by now i just have the cut out.
thanks so much!!
tom_germany
Postby toypusher » Tue Apr 07, 2009 12:40 pm
Staqrt by looking at the Generic Benroy Plans at the top of the page and see how the doors are done there.
Some pictures of how you made your door opening might be helpful!
toypusher
Images: 324
Postby planovet » Tue Apr 07, 2009 3:04 pm
There are a lot of things to consider...windows, how your sides are made and so forth. I used sandwich construction on my doors because that's how I did my walls. Wanted everything to be the same thickness. They will be a little heavier than a single piece of wood but they are solid and won't warp (at least I hope they won't).
Door cut out from side (3/4" birch)
Window cut out
Framing glued up (1x3 and 1x6)
Framing glued to outside skin
Insulation
Interior skin glued on (1/4" Red Oak)
Side view
Ready for finish
ImageMark (& Cindi)
planovet
The Cat Man
Postby 48Rob » Tue Apr 07, 2009 6:05 pm
Mark,
Nice Doors! :thumbsup:
Rob
48Rob
Postby kennyrayandersen » Tue Apr 07, 2009 6:16 pm
those door shouldn't warp!
kennyrayandersen
Images: 38
Postby starleen2 » Tue Apr 07, 2009 8:43 pm
Mark - you forgot to mention - plenty of clamps
starleen2
5th Teardrop Club
Postby planovet » Wed Apr 08, 2009 10:18 am
Thanks Rob and they better not warp! And like Starleen said, plenty of clamps will always help! When I first started out I think I had 4-6 clamps and now I have over 40 and it's never enough! :lol:
ImageMark (& Cindi)
planovet
The Cat Man
Postby Arne » Wed Apr 08, 2009 4:38 pm
I used built up walls and then cpes'ed them to keep moisture from penetrating as much and locking the fibers together,
... after the cpes hardened,
then I cut the doors out of the walls... so far, no warping..
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby mikeschn » Wed Apr 08, 2009 6:21 pm
the first doors I ever made...
Yep, those sticks are 3/4" thick.
I know the inside skin was about 1/4" I can't remember what the outside skins were... probably 1/2???
doors
Postby Tombstonebilly » Wed Apr 08, 2009 7:24 pm
:D What I like to do is after floor layout is to lay down on floor and act like its 3:40 am and those hotdogs(dinner) need to go for walk and make them to your size for easy and quick exit . they maybe need to be a just an inch or too but if you cut them to your comfort its worth it when you gotta go ! :shock: :o :o
Be The Person Your Dog Thinks You Are !
Tombstonebilly
