plastic galley hinge sealing
Postby madjack » Thu Apr 30, 2009 11:46 am
Mauleskinner wrote:
madjack wrote:...we used 1/2X1/16th flatstock AL w/screw(8X1"SSPan) every 2"s to eliminate any "pucker" factor...painted the trim and screw heads, black to match hinge color...we used auto windshield sealant/adhesive on the first one, which was overkill...we predrilled everything...cleaned up all the swerf and laid a heavy bead of a siliconized acrylic adhesive(WhiteLightning3600) on the current one and it seems to be working well...
madjack 8)
Sounds like a good plan, Jack...if 1/16" stock works, that's all the better!
I'm making a note of the WhiteLighting3600...is that a "standard" hardware-store-type sealant?
I get it at Southerlands...a big box store...it is similar to regular siliconized acrylic painters caulk but with an ADHESIVE component to it...it has worked well for us everywhere we have used it, besides it's CHEAP(less than 3bucks a tube) and comes in colors...another alternative is plain ol' putty tape, available at most hardware, box and RV stores........
madjack 8)
p.s. make sure you put a dab of sealant in all your predrilled screw holes..........MJ
Postby goldcoop » Thu Apr 30, 2009 4:28 pm
David & all-
Going into the 5th season with mine. It was just screwed to the top of TD body & hatch w/ alum threshold strip.
Just redid the attachment because of a leak.:x
New plan...
I peeled back EDPM rubber roof slightly on TD body.
Installed hinge to ply roof.
Covered hinge with a strip of EDPM (centered over width of the hinge). Reglued rubber roof to this whole "stack".
Reattached threshold strip with S/S screws.
On the top of the hatch the hinge stayed on top of the EDPM & was covered with the other half of the EDPM strip and covered with another alum threshold strip.
Things I have learned or would do differently...
Predrill holes thru the hinge slightly larger than the diameter of the screws you are using, Reduces those mother puckers.
I shoulda run the EDPM over the body & hatch in one large piece & not cut it... Then applied the hinge over this; woulda eliminated any chance of leaks!
Hope my rambling helps?!
BTW:
Hinge itself is holding up just fine :thumbsup:
Cheers,
Coop
goldcoop
Images: 32
Postby Mary K » Fri May 01, 2009 12:21 pm
Oh have I got Pictures for you....
This is how I installed the same hinge.
Pictures ARE worth a thousand words. Check out pages 6,7 & 8 of my Build pictures for more pics.
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Dan & Julie CO » Sat May 02, 2009 10:12 am
Flooring threshold pieces :awesome:
great crossover app of household product
I'm gonna put this one in my oh yeah box
Dan & Julie CO
Images: 56
