Mauleskinner wrote:madjack wrote:...we used 1/2X1/16th flatstock AL w/screw(8X1"SSPan) every 2"s to eliminate any "pucker" factor...painted the trim and screw heads, black to match hinge color...we used auto windshield sealant/adhesive on the first one, which was overkill...we predrilled everything...cleaned up all the swerf and laid a heavy bead of a siliconized acrylic adhesive(WhiteLightning3600) on the current one and it seems to be working well...
Sounds like a good plan, Jack...if 1/16" stock works, that's all the better!
I'm making a note of the WhiteLighting3600...is that a "standard" hardware-store-type sealant?
I get it at Southerlands...a big box store...it is similar to regular siliconized acrylic painters caulk but with an ADHESIVE component to it...it has worked well for us everywhere we have used it, besides it's CHEAP(less than 3bucks a tube) and comes in colors...another alternative is plain ol' putty tape, available at most hardware, box and RV stores........
p.s. make sure you put a dab of sealant in all your predrilled screw holes..........MJ
