sqweaka,s teardrop
sqweaka,s teardrop
Postby sqweaka » Thu May 21, 2009 2:38 am
just thought i'd run my plans by you guy's to see what you thought before i crack on with it next week!
my plan is to build a ultra lightweight teardrop trailer to tow behind a ford pop based hotrod! its got a 34hp motor so not much power to pull a heavy trailer! (may not manage this one but we'll see)
i've allready got a pair of light suspention units and will mount them to a simple A frame useing 2"X2" angle. going with small 8" trailer wheels to keep the weight down and the hight as drag will also be a facter to worry about. the floor will be 1/2 inch ply on a 1 1/2 inch frame with 2 cross beems in the middle also a hatch in the floor to let your leggs through when sitting in it!. sides will be again 1/2 inch ply with just one door, and some 1" by 1 1/2" soft wood for the roof spars to mount a 1/8" in ply roof.
i'm putting a 1/2" ply shelf in th rear to put all the camping gear on when sleeping in it and it will also double up as a area to put the kettle on.
all cooking will have to be outside with this one.
the whole thing will be glued and screwed and given a few coats of paint to seal it from the rain.
think that covers the main points. still not sure whats available to seal the door opening in the uk.
sqweaka
Postby Rigsby » Thu May 21, 2009 3:03 am
The plan sounds good to me. Nice and simple, no complications, should come in somewhere between 250 and 350 kg.
Now what are you waiting for? GIT_ER_DONE
DOOIN IT THE YAARKSHA WAY--FA NOWT, THA NUS !!
Rigsby
Postby kennyrayandersen » Thu May 21, 2009 3:46 am
not much fat there :thumbsup:
kennyrayandersen
Images: 38
Postby reiltear » Thu May 21, 2009 8:49 am
Welcome!
What Rigsby and Kenny said.
Plus, I guess you already looked at Angib's design and Steve Wolverton's Cowper.
Enjoy, and don't forget lots of :pictures: !!!
reiltear
Images: 18
Postby Miriam C. » Thu May 21, 2009 9:31 am
:applause: :thumbsup: Sounds good to me. So where are the pictures of the hot rod. :twisted: We love the pictures ya know. :thumbsup:
Postby sqweaka » Thu May 21, 2009 9:50 am
here you go
sqweaka
Postby sqweaka » Thu May 21, 2009 9:52 am
will get the steel for the chassis and the ply etc next week as im on leave from work. as its a simple trailer i'm after i'm hoping to get the bulk of it done in a day or two! weather permiting as i have no garage to shelter it under! ill also take plenty of photos
sqweaka
Postby High Desert » Thu May 21, 2009 9:59 am
sqweaka wrote:here you go
thats cool :thumbsup:
hotrod Paul would love that, it would go with his T bucket 8)
Shaun
High Desert
Images: 27
Postby Miriam C. » Thu May 21, 2009 11:06 am
:thumbsup: :applause: How cool is that! :thinking: Thanks for sharing the pictures.
Have you seen Roly's 1/4 Nelson? Or the Stacker? ? ?
http://tnttt.com/viewtopic.php?t=29868
Postby kennyrayandersen » Fri May 22, 2009 7:31 pm
That WOULD be a nice combo
kennyrayandersen
Images: 38
Postby sqweaka » Tue May 26, 2009 10:08 am
bought the ply and timber for the roof spars and floor frame today. hope to get a start thursday or friday. im on leave/vacation from wook for the week but the wife has a list of jobs for me to do before i can start the build :(
sqweaka
Postby Mini Renegade » Tue May 26, 2009 2:23 pm
Hi there, welcome to the nut house. If you are carefull you can make a full 4x8 with a hatch etc less than 300kg. i haven`t had mine weighed yet but its below the 300 mark.
I used a custom chassis with a "T" of 2" box with a 1" angle square around it to fasten everything down to. I used 1/2" ply on the floor and bulkhead with 3/8" ply walls. I managed a simple galley and interior cupboards as well. In fact its for sale shortly........
If evvr tha dus owt fr nowt, allus do it fr thissen
Mini Renegade
Postby Fenlason » Tue May 26, 2009 7:48 pm
sweet car.. :thumbsup: :thumbsup: :thumbsup:
glenn
Kahlil Gibran
George Bernard Shaw
Fenlason
Tour de Post Yellow Jersey
Images: 221
Postby sqweaka » Thu May 28, 2009 3:20 pm
wed, started to build the teardrop, cut both sides with a jigsaw and clamped them together, sanded them smooth round the cut edges, then predrilled the sides for the spars, cut the floor to size and made a frame to go under it, screw n glued the base together
today fitted the sides to the floor, and glued and screw'd the roof spars in place!
that done glued the spars and sides and fitted the 1/8ply roof front section nailing it to the sides. clamped the whole thing down with some ratchet straps, sat back and had a couple of beers.
took some pic's but still having problems loading them to my computer so ill add them later.
sqweaka
Postby sqweaka » Fri May 29, 2009 1:09 pm
today fitted a two section shelf, at half hight in the back of the teardrop its hinged so when not in use the front part of the shelf can be folded up to give more seating area!
then fitted the rear half of the roof skin. nailed glued and clamped as per the front secton and held overnight with the ratched straps again.
while the glues drying i routered the roof flush with the sides and went off to collect some 2"x2" angle iron to make a simple A frame chassis over the weekend
jobs left to do to the body
make a door, hatch in the floor, air vents in the side panals, seal with thinned varnish and a few coats of paint. oh and weld n fit the chassis, should be done by next week fingers crossed!
sqweaka
Users browsing this forum: Bing [Bot] and 8 guests
