ICE BOX CHOICES
Postby RKH » Sun Sep 11, 2005 11:34 am
Take a look at the Igloo Coolers website. They will give some guidance on sizing. HTH
~Keith
Support Our Troops
Our traveling blog is at http://www.Happy-Tracks.com
RKH
Images: 16
Postby IraRat » Mon Sep 12, 2005 7:42 am
Gerdo wrote:Try Dry Ice. I used 7lbs for a 3 day trip and when I got home there was only a small peice left. You need to keep it in an air tight bag to make it last the longest. Also put a peice of cardboard between iye ice and your supplies. Works great and your food doesn't get all wet.
I thought that freezes stuff.
--Ira
IraRat
Forum Storyteller
Postby Gerdo » Mon Sep 12, 2005 2:02 pm
If the Dry Ice comes in direct contact things then they will freeze solid. But if you keep a layer of cardboard between the ice and your supplies you will have cold, dry supplies.
Give it a try.
Gerdo
Images: 156
Postby goldcoop » Mon Sep 12, 2005 3:04 pm
For a more finished look, you may want to try a built in...
Check out (from the links): http://www.formcoinc.com/ice.html
We used one of their boxes in the Ctear, has a drain tube (that drains out the bottom thru the floor) Works & looks great!
Cheers,
Coop
goldcoop
Images: 32
Postby xe1ufo » Mon Sep 12, 2005 11:59 pm
Hey Coop: Thanks for the link, but it doesn't work.
Dr. Steve
Central old Mexico
xe1ufo
Postby Roly Nelson » Wed Sep 21, 2005 11:58 pm
My daughter gave me a 12v/110/v electric refer, and it works great. I didn't want to build it into my tear, since I place it on the table when at campsite. What is nice about it is that I keep it in the back seat while on an extended trip, (like Shasta) and it cools the inside 40 degrees cooler than the outside temps. That means that if the inside of the car is 70, the cooler will freeze ice on the bacon and milk bottles.
I am very happy with it, and will never plug it in incorrectly again. I checked on the temps of my cold drinks while in the desert and the inside of the unit was 110 degrees. Whew. That's what happens when I put the red battery connection on the negative post. No cooling, just heating. But I am learning.
Roly~~
Roly Nelson
L'il Ol' Woody Builder
Postby Will Smith » Thu Sep 22, 2005 9:28 am
We use two 52 quart coolers for a long weekend.
Benefit mankind, use your screen saver for something useful. More information here:
http://www.worldcommunitygrid.org/
Will Smith
