Len
Thanks for your professional input!
Do you have any pics of a small 3way fridge that is set up to be a free standing unit?
Seth
eamarquardt wrote:Yup, when I said "blind" I meant the reefer would be installed in a box without "normal" ventilation.
Re: carbon monoxide-the reefer enclosure will be separated from the sleeping compartment by a storage space. Thus there will be two virtually air tight bulkheads (excuse the Marine vernacular as I are one and also owned a sloop and if I win my lawsuit against AT&T and get punitive damages I may buy another one (or even if I don't win if may buy another if my wife provokes me as I'm managing my "disease better" and could probably take care of it with a little help, I digress) between any combustion gases and the sleeping compartment. I can't forsee compustion products getting into the sleeping compartment under any circumstances.
Re: dangerous-propane explodes under the right conditions, so make sure you don't have the "right conditions". The big issue in a blind installation is getting rid of the hot air at the top of the system some how using ductwork to the outside. The bottom of the reefer will still be easy to vent. So you make sure the bottom of the system is wide open, well ventilated, etc. to the bottom of the tear. Propane is heavier than air and will decend out this opening and disapate. If the bottom of the reefer is open and well ventiated there is nothing different about a blind installation than a conventional installation. We had a propane oven and range in our boat for years and never had a problem even though the bottom of the boat was air (and water) tight! Using propane in a tear is a whole lot safer than in an air and water tight boat!
Re: impractical-I disagree. I have made a mock up of the profile of my tear (see album) and the only concession was to make the back of the tear a little more squared off than might otherwise be required. Using a couple of inexpensive fans and snap thermostats you can have a fully redundant system to vent the hot gasses at the top of the coils. Current draw of the fans is minimal compared to the other loads people demand of their batteries.
Re: maintenance-I disagree. I haven't seen any "conventional" installations where the reefer doesn't have to be removed for servicing. The items that might require service are on the top and at the back of my unit. Virtually any installation will require the unit to be removed from it's enclosure, so a "blind" installation isn't any different than a conventional installation.
Re: placing the unit in the TV. Running the unit on propane in the TV could get verrrry exciting (if you have a leak and then an exposion) or very dull (if the combustion gases poison you and put your "lights out") so I can't recommend that idea. Norcold says unit works at 100% on propane or A/C in regards to max cooling. Running it on DC is intended to only maintain the "status quo" not really cool things down. So keeping it in the TV on DC could work but it would be dumping about 250 watts or so of heat into the TV. I wouldn't think that would be an issue in cooler weather or if the vehicle has A/C
The neat things about building your own is gettin what you want. I think moving a loaded reefer around would be more of a pain than doing a one time install. Having done a fair amout of crusing in my boat, I really missed refridgeration and enjoyed a good oven and plan to have both built into my tear. I agree that you can't do the installations "half aXXed" or you might nominate yourself for a Darwin Award (to be awarded posthumously).
After reading the comments, I think I'll contact Norcold again and see about optimizing the ductwork or do some more testing. I got a really neat Fluke digital temp meter for a buck at a garage sale and a lifetime supply of thermocouple wire at a junk yard for $5. I can install the reefer and moniter the temps and see "what's cooking".
There you have it: The world according to Gus. Rebuttals welcome as we might learn something!
Cheers,
Gus
Users browsing this forum: Google [Bot] and 4 guests
