by madjack » Sat Jul 11, 2009 11:56 am
ssample wrote:madjack wrote:I'm not a fan of house paint for a finish but more importantly is what is underneath it...with epoxy/CPES sealing all wood(you do have it all sealed...doancha), you should be able to get away with house paint...have you checked on the cost/availability of marine urethane paint...it is available in several colors and I can buy it at my local hdw and box stores..........
p.s. keeping the tear under cover while stored will go a loooooooong way to protecting that paint finish...........MJ
Hi,
I am almost to the exterior finish stage and would appreciate your opinions on if I should seal the entire body? I have sealed all of the plywood edges already with CPES from Rot Doctor. I plan a Filon or epoxy based paint as the exterior finish. It seems a waste of money if I use the Filon, because the contact cement will cover all the wood. Thanks
...if you are going to paint, I would certainly seal everything with the CPES(or regular epoxy) first...a marine urethane based paint over that and you should be good to go...the filon...if ya want it...use it..............
p.s. any epoxy, CPES or otherwise, should have a minimum of 3 coats for best sealage...the same applies to the paint as weil...any sharp edges on exposed wood should be relieved somewhat to eliminate those sharp edges which will turn into a point of failure if not......MJ
