Galvanized sheet metal
Postby Frosteez » Fri Aug 14, 2009 10:47 pm
Hey Danny- we used 26 ga. from a heating and air shop. They use it in ducting. Got 2-5x10 sheets for about $70.00. Took 2 days to get. Couldn't find alum. in 5' wide. And at 1 1/2 sheets for the tear it doesn't weigh that much more. We had a friend paint it to match Cathy's car. Looks great and the way I shove it into things, I'm sure aluminum would be history by now.
Frosteez
galvanized
Postby Danny » Fri Aug 14, 2009 11:26 pm
Frosteez wrote:Hey Danny- we used 26 ga. from a heating and air shop. They use it in ducting. Got 2-5x10 sheets for about $70.00. Took 2 days to get. Couldn't find alum. in 5' wide. And at 1 1/2 sheets for the tear it doesn't weigh that much more. We had a friend paint it to match Cathy's car. Looks great and the way I shove it into things, I'm sure aluminum would be history by now.
Yeah, that is what I have 26 gauge. Nice and shiny. How did you prep it for paint? Primer used? Top coat?
Danny
Images: 108
Postby Prem » Sat Aug 22, 2009 5:36 pm
Has anyone used galvanized for roof tops on their builds? It seems to me this would be a very durable product. Galvanized comes with an oily coating which must be removed with a water based acid wash. Some old timers recommend vinegar and water. I also have found several spar varnish brands that say to use spar varnish on metal to protect against uv rays and salt air. Galvanized will break down if left untreated and exposed to air. It is called white rust and of course dulls the appearance. gloss marine varnish should seal it up and keep it shiny. How have your results turned out??
Galvaneal! Comes acid etched and ready to paint. Use Imron or Acrylic enamel with hardener.
But if you really want the finest...what Dean said!
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby Sparky » Sat Aug 29, 2009 6:41 am
used it for my roof 4yrs ago just started turning white. works good and a little hillbilly but thats what we like :thumbsup:
Sparky
galvy
Postby Danny » Sun Aug 30, 2009 11:20 pm
8) I just put mine on thursday and got it all sealed up and trimmed out, Yeah I know pix..The sides are still woody and the trunk lid also. just the top and front are metal now looks great. Tin top woody!! :thumbsup:
Danny
Images: 108
tin
Postby Danny » Wed Sep 02, 2009 12:55 am
Located a black vinyl trim product that works great for trimming out the top/side joints. Mfg. Big orange I think, Armtex or something like that :lol: LOL. Anyway, it works good and is cheap. 2 bucks for a strip 6.5 feet long 8) I like the black trim between the woody sides and the metal roof. Also put in new hunter green carpet. promise to shoot pix this week and will post finished tear pix. Danny
Danny
Images: 108
NEW PIX OF MY TEARDROP
Postby Danny » Fri Sep 04, 2009 5:01 pm
As promised :) I took some pix of my tear. They are now in my album...Danny
Danny
Images: 108
Postby starleen2 » Fri Sep 04, 2009 6:25 pm
OOOoooo - so shiny :thumbsup:
starleen2
5th Teardrop Club
Postby Miriam C. » Fri Sep 04, 2009 8:13 pm
:applause: :thumbsup: :thumbsup: :woohoo: :beautiful:
You are almost done! So what is this black vinyl and how does it do on the curves? Does it shrink to fit?
strips
Postby Danny » Fri Sep 04, 2009 10:15 pm
Miriam C. wrote::applause: :thumbsup: :thumbsup: :woohoo: :beautiful:
You can see them in the photo above. They are the same shape as the aluminum ones we are all used to except they are a composite material very bendy and easy to use. and 1 1/2" wide. They have screw holes every 8 "..They come in 6 1/2 foot lengths. 2 bucks per strip. they have an edge(lip) that goes over the sides. I will try to take a picture of a strip next time I have the camera outside :roll: Found them at a box store.
Danny
Images: 108
Postby Danny » Fri Sep 04, 2009 10:18 pm
Danny
Images: 108
trunk/strips
Postby Danny » Fri Sep 04, 2009 10:21 pm
Danny
Images: 108
tintop woodies
Postby Danny » Wed Sep 23, 2009 1:33 pm
So, is anyone else using galvanized on their build? I have 2 more on the drawing board both will be 78'' long on a small HF trailer. I need to clear out the shop first though. Must get some trailers sold before next project.
Danny
Images: 108
