laoutdoorsman wrote:well you could bolt a milk crate down, drop the tank in it, then bungee cord thru the handle hooked to eyebolts..........but..i guess that would be the redneck way...lol
kennyrayandersen wrote:laoutdoorsman wrote:well you could bolt a milk crate down, drop the tank in it, then bungee cord thru the handle hooked to eyebolts..........but..i guess that would be the redneck way...lol
And probably not too safe in case of any kind of accident I’m afraid. It’s always cheaper to do it yourself, but you have to buy a welder and practice a bit. There are a lot of talented fabricators on the forum. If you can find something simple, you can always have a local welder do it. I’ll probably buy a welder shortly, but in the meantime I’ve had several things welded buy a local shop and usually for $20-50 bucks (depends on how big of a job it is).
laoutdoorsman wrote:kennyrayandersen wrote:laoutdoorsman wrote:well you could bolt a milk crate down, drop the tank in it, then bungee cord thru the handle hooked to eyebolts..........but..i guess that would be the redneck way...lol
it was just a joke...im now convinced...you MUST be an engineer.....
kennyrayandersen wrote:laoutdoorsman wrote:kennyrayandersen wrote:laoutdoorsman wrote:well you could bolt a milk crate down, drop the tank in it, then bungee cord thru the handle hooked to eyebolts..........but..i guess that would be the redneck way...lol
If I hadn't seen it, I wouldn't have believed it!!! You know, down south, we see some real redneck contraptions -- I've actually seen something nearly like you were describing; therefore, I don't assume anything anymore. Being originally from the north, I wouldn't have considered it -- I guess I been in TX too long![]()
kennyrayandersen wrote:Just as an interesting side-note: being from Washington State, and Washington State having neither enlisted in the war between the States, nor even existing as a state at the time, cannot, technically, be a ‘Northerner’… or so I’ve been told.
Also, not being raised on the ‘left’ part of the state, I Could easily be given [political] minority status
Rednecks -- you can live with them, but your life MAY be in danger...
