I started a build in Mo
Postby Darren » Thu Sep 10, 2009 9:55 pm
Very nice Wayne. Keep the photos coming.
Darren
the camper formerly known as Victor Star
Images: 161
Postby WayneFromMo » Fri Sep 11, 2009 9:27 am
Doug
I robbed the Assembly off a wrecked RV. I couldn't use the door because it had a large dent and a hole that was drilled into it to hold the door shut.
I made that door that is seen in the picture from a sheet of 3/4 and 5/8. At first it was straight and when I mounted it to the frame. After it set out all night the first night, it bowed now it's hard to latch. So I'm going to build a framed door and replace the current door.
Thanks Doug. If you have any other questions please ask.
Thanks Victor.
The only thing keeping anyone from being a genius is motivation- Albert Einstein
My build
http://www.tnttt.com/viewtopic.php?t=31105
WayneFromMo
Images: 92
Postby robertaw » Fri Sep 11, 2009 10:21 pm
WayneFromMo wrote: Almost ready to install the Mossy Oak paneling
:thumbsup: I'm going to have to Google that - I've never seen it.
Roberta
robertaw
Images: 56
Postby WayneFromMo » Sat Sep 12, 2009 8:10 am
I ordered it through a local lumber yard. It sells for $27.00 a sheet. I bought the Mossy Oak Breakup pattern.
My build
WayneFromMo
Images: 92
Postby robertaw » Sat Sep 12, 2009 9:49 am
WayneFromMo wrote:I ordered it through a local lumber yard. It sells for $27.00 a sheet. I bought the Mossy Oak Breakup pattern.
Very cool! Can't wait to see pics! We did our first RV reno in Mossy Oak them but didn't know about the paneling then. Would have been a nice addition.
Roberta
robertaw
Images: 56
Postby WayneFromMo » Thu Sep 17, 2009 5:22 pm
Here is Some pictures of the Mossy Oak paneling that I purchased.
I bought it from a local lumber yard. You might check one in your area.
My build
WayneFromMo
Images: 92
Postby robertaw » Thu Sep 17, 2009 6:57 pm
Nice! Good pattern choice too. Alot less busy than some Mossy Oak so better suited for a small space.
Roberta
robertaw
Images: 56
mossy oak..
Postby laoutdoorsman » Thu Sep 17, 2009 7:58 pm
they have the mossy oak stuff at the lowes here in hammond, la...7 something a sheet...BUT...its just an osb (7/16 or 1/2 ??) with the mossy oak sticker or wrap on it...i fooled with while waiting to check out today...the wrap was peeling of the corners...im sure it wouldnt last very long...
hope the stuff you have is better than what i saw...lol
mike breaux...its pronounced "bro".....
i think i should have taken notes along the way, because ive forgotten waaaay more than i remember...
laoutdoorsman
Images: 44
Postby WayneFromMo » Thu Sep 17, 2009 8:20 pm
I checked this stuff out before I bought it. I've been stuck with the glue and saw dust before.
This paneling is solid wood about 1/4 inch thick. Good stuff. :thumbsup:
Wayne
My build
WayneFromMo
Images: 92
Postby S. Heisley » Fri Sep 18, 2009 12:00 am
Wayne, that Mossy Oak paneling will really set off your interior and make it different from everyone else's. It'll look great. You're going to have a nice trailer. Thanks for sharing your pictures and your build. :applause:
Postby WayneFromMo » Sun Sep 20, 2009 7:18 pm
I don't mean to tease, but I installed the
Mossy Oak paneling this weekend. I would take some pictures but the batteries were down and they need to recharge. I'll post some pictures later. But the paneling dose look good installed. :thumbsup:
My build
WayneFromMo
Images: 92
Postby WayneFromMo » Sat Sep 26, 2009 9:58 pm
Some one asked how I built my door, this is how.
Irip some one bys to the desired thickness of the door. (Minus the outer two layers).
I fastened the two outer layers together. I'm using 1/4" BC plywood. Layout the shape of the door and cut out. I used a skill saw, Jig saw, and router on this door.
I cut the one bys to fit. I fasten the one bys to one side with glue and brads. I used plywood in the corners and cut the radiuses.
Insulate the door, and attach the other side and that's it.
Doors are easy.
My build
WayneFromMo
Images: 92
Postby WayneFromMo » Sat Sep 26, 2009 10:09 pm
OK here is the Mossy Oak up.
Roadside rear.
Roadside front.
Curbside front.
Curbside middle.
Curbside rear.
I like it. I know it's not fine woodworking, but I still like it.
Wayne
My build
WayneFromMo
Images: 92
Postby WayneFromMo » Sat Sep 26, 2009 10:13 pm
I also started putting the outside skin on.
Bending the plywood over the 24" radius.
View from the other side. I'm also using liquid nail to help.
Wayne
My build
WayneFromMo
Images: 92
Postby S. Heisley » Sun Sep 27, 2009 9:58 am
Looks good, Wayne. Most of us are amateurs; but, I've seen some our work that is better than what many professionals do! :thumbsup: You're going to have fun, camping in that.
Users browsing this forum: azgreg and 9 guests
