small TD
Postby Aaron Coffee » Fri Sep 18, 2009 4:31 pm
Update with pics
floor on frame
walls are up
I should have made the floor the length of the body, I think I will extend the floor on both ends.
The long cross piece repesents where the hatch will start and the longitudinal on the wall is approximately the height of the shelf.
One last thing any ideas on how to incorporate this into my build(bought it unused at an auction for $1.
Thanks
If I could shut my brain off, I could save myself alot of time, money and effort.
Aaron Coffee
Images: 26
Postby Jst83 » Fri Sep 18, 2009 4:47 pm
:applause: Very nice
Couple questions as I'm following this thread planning my tiny tear.
What size trailer is that and is 107" long and 43 1/2 tall the actual size of the plywood sides?
Which leads to the sides, how did you do the pattern? Very nice :thumbsup:
Jst83
Images: 215
Postby Aaron Coffee » Fri Sep 18, 2009 7:02 pm
trailer started out as a 40 wide x 48 long nu-way kit from Menards, I made new side rails and stretched it to 75 inchs long. Walls are 107 1/2 or so and 43 1/2 tall.
I downloaded the dxf from the design library for the cub. I was going to have one of the engineers at work resize it for me, got bored of waiting so I just played around with turbo cad until I got it close enough to the size I wanted, then played around and figured out how to get a point by point measurements and used those dimensions to draw it out on cardboard.
Aaron Coffee
Images: 26
Postby Jst83 » Fri Sep 18, 2009 7:22 pm
I took the grumman profile and shrank it down to 6' long in photoshop, gonna go with the 40" wide.
So it's a camper 40" wide by almost 9 feet long?
So how was the diamond side design done?
Jst83
Images: 215
Postby Aaron Coffee » Fri Sep 18, 2009 7:53 pm
The pattern on the side just happened to be there, I think it has something to do with the way the veneer was cut. I answered an add on craigs list for hardwood plywood for $20 a sheet(bought 5 sheets, 4 hickory, and one cherry). Saw the 2 sheets of hickory with the scallops and knew right away which ones were going to be the sides, in the planning stages I was thinking paint with scallops. used the cherry on the floor. The sleeping area will be 75 1/2, just the right size for a single mattress, the rest will be storage. After I get my trim done then I will varnish with an hvlp gun(unless winter beats me, then it will have to wait for next spring)
Aaron Coffee
Images: 26
Postby Jst83 » Fri Sep 18, 2009 8:04 pm
Thank you for the info and I'll keep watching.
Jst83
Images: 215
Postby Senior Ninja » Fri Sep 18, 2009 8:08 pm
Please don't forget to repack those wheel bearings. It appears that the trailer may have sat for a while and those smaller wheels are going to be really spinning fast on the highway.
Building the TD was the best thing I ever made.
Senior Ninja
Postby Aaron Coffee » Sun Sep 20, 2009 7:41 pm
Yep, trailer has set since 2004, thanks for the reminder. Looks like I will need a new tongue as this one only extends about 18 inchs past the most forward part of the body.
Got the floor extension supports done. Just need to cut plywood yet and pull it apart and epoxy the new peices.
Here is the rear both of these where cut from 2x4 and will also act as spars.
Here is the front, the crossmember with the red X will also act as the first spar where the aluminum will start. I goofed when putting the walls up I put them level with the frame rails and forgot that the tongue is actually 1/8 higher than the side rails and wouldn't have been able to get the first spar in at the start of the current floor, and wouldn't have had room to get any screws in.Image
everything underneath will get three coats of epoxy.
Aaron Coffee
Images: 26
Postby Aaron Coffee » Tue Aug 23, 2011 8:37 pm
Two years and I'm still not done! Have made some progress.
Galley done.
Cabin Shelf
Wheel, tires and fenders mocked up
Tongue lengthened. Still need to have braces welded.
Aaron Coffee
Images: 26
Postby S. Heisley » Tue Aug 23, 2011 9:12 pm
Aaron, I like the shape of your galley. :thumbsup: Oh, and don't worry about when you get done. You're on teardrop time!
Postby Lgboro » Thu Sep 01, 2011 3:08 pm
Looks good to me too --- I may have to put one of my other projects further back on my project list and build a mini. Really nice build so far. I hope to build an aluminum frame for my mini when I build. Your build should help me a lot when I get funds to build (and finish my 4x9).
Lgboro
Images: 53
Postby Cliffmeister2000 » Thu Sep 01, 2011 3:17 pm
Glad to see you back at it! :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby Aaron Coffee » Sat Sep 10, 2011 6:08 pm
Took #2(need a better name for it)to a car show today, still needs varnish and my little boo-boos fixed, and windows and door sealed. Got an invite to an by invitation only car show the end of October, so it looks like I will have to continue busting my butt to get it done. Taking the night off though, and going to a street dance. Will post pics tomorrow.
Aaron
PS. I would like to thank those that know more than me (everybody)for giving me the confidence to attempt the stuff I have never done and for giving advice when I ask stupid questions.
Aaron Coffee
Images: 26
Postby Aaron Coffee » Sun Sep 11, 2011 2:37 pm
Here are updated pics and looking for opinions.
Opinions wanted: White insert trim, leave it or sand/strip it down to mill finish?
Fenders? Red to match body or black or some other color?
Any ideas on a galley hatch? Bought some lockable latchs at menards and they won't work. Kind of thinking of model A hood latchs but then don't have lockable option.
any other thought, ideas, comments, etc.
Thanks
Aaron
Thanks
Aaron Coffee
Images: 26
Postby parnold » Sun Sep 11, 2011 10:02 pm
I don't see the bedpan in your last batch of pictures. I was thinking you'd turn it into a sink.
:lol:
Very nice looking trailer.
:thumbsup: :thumbsup:
parnold
Images: 302
