Anybody ever use this one ? Electrical Converter/Charger
Anything electric, AC or DC
Postby Chris D » Wed Oct 07, 2009 1:08 pm
Elixir Industries ELX-30 Amp.
Converter/Charger/Control center. Seems to be easy to hide or left to see. It has a nice black cover and a varidible speed cooling fan.
Chris D The semi new guy :lol:
Chris D
Converter
Postby Chris D » Wed Oct 07, 2009 7:51 pm
Anybody :thinking:
Chris D
Re: Anybody ever use this one ? Electrical Converter/Charger
Postby wlooper89 » Wed Oct 07, 2009 7:54 pm
Chris D wrote:Elixir Industries ELX-30 Amp.
I found a big variation in price online so it might be good to shop around. This is a link to some discussion about the unit.
http://www.popupexplorer.com/forum/inde ... ic=73424.0
One person in the thread complained about noise from the unit when it was under a load.
One other thing concerned me a little. There was no mention of 3-stage charging in the online description. This feature means the voltage output is automatically decreased in steps as the battery becomes fully charged. With a 3-stage converter it can be left connected to the battery indefinitely to maintain the battery. Although the ELX 30 might work fine, I would still go with the WFCO 25 or 35 amp converter. Mine is the WFCO 8725, and 25 amps has been plenty for my needs. :)
Bill
wlooper89
Images: 75
Postby TPMcGinty » Wed Oct 07, 2009 7:55 pm
Tim
TPMcGinty
Images: 146
Postby Steve_Cox » Wed Oct 07, 2009 7:56 pm
Chris,
I have a converter/charger in the gypsy trailer, not the same brand as the one you asked about. It made wiring the 12 volt easy as it had built in fuses and terminal strips. Mine is under the bed and is pretty quiet. Money well spent in my opinion.
Steve_Cox
Images: 196
Converter
Postby Chris D » Wed Oct 07, 2009 8:19 pm
50.00 bucks seemed fair. I will have 2 110v outlets /2 12v outlets /3 12 volt lights 1 overhead cabin and 1 galley hatch and 1 outside porch light no more than that. Will it handle that guys.
Thanks
CD
Chris D
Re: Converter
Postby TPMcGinty » Thu Oct 08, 2009 6:39 am
Chris D wrote:50.00 bucks seemed fair. I will have 2 110v outlets /2 12v outlets /3 12 volt lights 1 overhead cabin and 1 galley hatch and 1 outside porch light no more than that. Will it handle that guys.
Thanks
CD
Mine's a 20 amp converter. I have one galley light, two reading lights, two overhead lights (I should have put in only one), two porch lights, 3 12v outlets, and 3 110v outlets.
Tim
TPMcGinty
Images: 146
Postby wlooper89 » Thu Oct 08, 2009 7:15 am
I am sure you all know this but just in case it might be helpful to someone, the 110V outlets in the trailer are not part of the converter load. They are just a load on the campground power outlet. Also a 30 amp converter will only draw about 5-6 amps AC at max load.
There is a 10 to 1 difference between AC and DC amps as expressed by the little formula Amps = Watts/Volts. That would make the converter amp draw 3 amps AC at 30 amps DC load, but there is some inefficiency in the converter such as heat produced. The formula can also provide the number of amps used by a light or appliance if only the watts (and volts) are known.
Good luck with your build! :thumbsup:
Bill
wlooper89
Images: 75
Postby JIML1943 » Thu Oct 08, 2009 8:06 am
Nope. I have one of these:
http://cgi.ebay.com/ebaymotors/RV-trail ... 5635b68d5b
Works fine.
_________________
I've been using one of these for four years no problems.
Some days all you can do is smile and wait for some kind soul to come along and pull your ass out the bind you've gotten yourself into.
Happy camping Jim & Barbara
JIML1943
Images: 71
Return to Electrical Secrets
