Thanks Greg
Here is an example of one of my trailers
Moderator: 2bits
ronaldito wrote:I should warn you that if thats your final pruduct of trailer, it looks very unsafe... it really needs to be reinforced, or when you finish your build, you going to tear the heck of off the corner welds and have a disaster
ronaldito wrote:The tongue is poorly attached to main frame, dangerous trailer to pull if you put weight... you better return trailer and have this "expert trailer builder" to put a beam between the middle of the hitch to the middle back of the trailer. Put this in cargo trailer or teardrop forum and ask for opinions...
madjack wrote:...the receiver needs a back connection to eliminate flex/twist that is going to occur under load(this is a big concern to me)...
madjack wrote:...I don't feel it would be "unsafe" as such BUT I do have two concerns...first, I would run the tongue all the way back to the second crossmember(first on inside of the perimeter frame) and second is the receiver needs a back connection to eliminate flex/twist that is going to occur under load(this is a big concern to me)...with these two modifications, this would be a super frame to build on..........
