Larwyn wrote:There is a small drum brake inside the rear disc brake rotor on these trucks and the story is if you do not use the emergency brake regularly it will get out of adjustment, rub and wear to the point of no longer working.
Larwyn made the cooment that he never uses the E-brake, to suggest that the cable was stretched doesn't make any sense either.caseydog wrote:Larwyn wrote:There is a small drum brake inside the rear disc brake rotor on these trucks and the story is if you do not use the emergency brake regularly it will get out of adjustment, rub and wear to the point of no longer working.
Okay, I gotta wonder about that. That makes no sense. I would be more inclined to think that the E-brake is just a cable system that operates the rear disc, and that the cable has stretched.
That is how every other four disc system I have seen works.
Putting a drum inside a disc system just adds parts for no reason. Why?
Check again. That just doesn't make sense.
CD
CD
Kevin A wrote:Larwyn made the cooment that he never uses the E-brake, to suggest that the cable was stretched doesn't make any sense either.caseydog wrote:Larwyn wrote:There is a small drum brake inside the rear disc brake rotor on these trucks and the story is if you do not use the emergency brake regularly it will get out of adjustment, rub and wear to the point of no longer working.
CD
Here's a link that supports what Larwyn posted.
http://www.carcomplaints.com/Chevrolet/ ... ions.shtml
2000 CHEVROLET SILVERADO -- In a letter dated April 20, 2005, GM notified NHTSA that it had decided that defects that relate to motor vehicle safety exist in certain model year (MY) 1999-2002 C/K 1500 series (PBR parking brake system) and MY 2001-2005 C/K 2500 and 3500 series (TRW parking brake system) pickups with manual transmissions. According to GM, some of these vehicles may have conditions that cause the friction linings to wear to an extent where the parking brake can become ineffective in immobilizing a parked vehicle. GM's action covers an estimated total of 142,585 vehicles. Dealers will install a low-force spring clip retainer for vehicles equipped with the PBR parking brake system and install a redesigned parking brake cable assembly on vehicles equipped with the TRW parking brake system. A total of 58 non-duplicative complaints were received by ODI and GM concerning the approximately 59,000 MY 1999-2002 C/K 1500 series pickup trucks with the PBR parking brake system. These included 22 alleged rollaway incidents, resulting in a rate of 38.5 rollaway incidents per 100,000 vehicles. ODI is aware of 24 complaints regarding the MY 2001-2005 C/K 2500 and 3500 series manual transmission trucks recalled by GM, including 5 alleging rollaway incidents. Though the conditions described in GM's letter are also present in the C/K trucks with automatic transmissions, the rollaway rate in those vehicles was similar to those observed in peer vehicles studied by ODI in this investigation. This engineering analysis is closed. For additional information, see the attached closing report. Investigation was initiated on April 09 2004. Closed on May 10 2005. For detailed information & supporting documents, see the official NHTSA page concerning investigation #EA04011 »
caseydog wrote:OMG, there really is a drum within a disc parking brake on a bunch of GM trucks. WTF were they thinking. Is there any wonder why the government had to bail out GM?
It took me a little research, but some nimrods were apparently reluctant to leave behind the drum brake, so they put an almost useless drum within a disc parking break on the otherwise 1950s technologies of the full-sized GM truck.
So, I was wrong. GM is even more bassakwards than I thought they were. I can not think of any good reason to not use the discs that are already there to also serve as a parking/emergency brake.
I learn something new every day -- not always something that makes me happy.
CD
Jiminsav wrote:I think Ford uses a spiral inside the caliper to spin the puck out mechanically as a parking brake.
