Re: New TTT - The Boxcar - New Sliding Bed
Postby doug hodder » Wed Jul 01, 2009 10:44 pm
Bruce....don't know what to say....absolutely outstanding guy! Thanks for the updates on it. Think you can make it out to the IRG this next summer? I'm looking forward to seeing this critter all done! Hey everyone, party in Bruces trailer! Doug
Postby bdosborn » Sun Jul 05, 2009 6:38 pm
Gosh Doug, I appreciate the kind words. Heck, I stole most of my ideas from you so your compliments mean a lot! :thumbsup:
Images: 806
Postby bdosborn » Wed Oct 07, 2009 7:49 pm
TinKicker wrote:Bruce, is your trailer in the Build Journals section? I'd like to see how you did it. Way awesome work, man! :thumbsup: :thumbsup: :thumbsup:
Bump.
Here's the build thread. I guess I started this before I knew there was a section for builds.
And to tie it into the build thread, here's the first outing thread:
First Outing Clicky
Images: 806
Postby bdosborn » Fri Oct 23, 2009 6:57 pm
I made another build video, this one is for the boxcar:
http://www.youtube.com/watch?v=wSuLYxQOfl4
Gosh, two years only takes 8'26". Seems like is should lake longer than that.
:lol:
Images: 806
Postby mikeschn » Fri Oct 23, 2009 7:53 pm
Very nice job Bruce!
Two years condensed into 8 minutes... whodathunk? :?
Postby Team Varekai » Sat Oct 24, 2009 12:47 am
Bruce, what can I say.......Truly amazing :applause:
Absolutely phenominal build and really enjoyed the slide show on youtube
btw. who were artists and what were the songs playing during the vid?
Team Varekai
Images: 6
Postby bdosborn » Mon Oct 26, 2009 10:23 pm
Team Varekai wrote:btw. who were artists and what were the songs playing during the vid?
Thanks guys! The artist is Brian Bromberg.
Images: 806
Postby Ron Dickey » Thu Oct 29, 2009 2:11 am
Very very very impressive!!
After you get done there is a question in the Poll site, If you had it to do all over again what would you do differently.
If I make a bigger one it will have a double axel like the Maxitear.
But the work you show of the inside makes me realize where i went wrong on mine, having never made one before nor anything like that.
This should be in a plans site or on a CD for you to make funds back on.
How much planning was put into it before starting and how many times did you find yourselves saying no this will not work lets try this.
In you Box Car what did you change the most that you knew would not work by the time you finnished this trailer.
You show how much real Fraiming make all the difference to the assembly prosidure.
Did Georges in CO influence your design much? which as I remember also had a back door and smaller raized top.
Most of us are influenced by what we see in others trailers.
173882......173887
Ron Dickey
Images: 787
Postby bdosborn » Fri Oct 30, 2009 6:26 pm
Ron
I've been very pleased with how its turned out. The only thing I would consider changing is the pop-top. I love having it but I'm not real keen on how it goes up and down. I think I would look at hinging it to the body instead of having it go straight up. But, I went I went with the design I did because I thought the overall structure would be stronger with a minimum of open area on the roof. The teardrop flexes enough over curbs that I had to shim the door latches so they wouldn't come open. I was worried that the Boxcar walls would flex during travel and the barrel latches in the pop-top wouldn't line up. So far, the walls have been rigid enough that the pop-top has lined up even after the trailer bounced around on 20 miles of washboards. So its like any design, there's always trade offs and rarely a perfect compromise.
I like the Maxitear too and thought about using a tandem axle. After a lot of thought I decided to stay with a single axle.
- Its a cheaper over time not having to buy an extra pair of tires.
- A single axle is lighter than a tandem.
- The trailer turns better on a single axle.
- Less interior space dedicated to wheels.
I spent a *lot* of time thinking through the design so I didn't run into much that I changed as I went along. I spent the most time thinking about how the pop top would work. I ended up trimming the side panels a bit after I had made them (and caught the pocket screws in the saw!!) but that's the part I fiddled with the most. I think building the interior before the exterior helped with the wall planning. I placed everything on the floor and then framed around it. It was a bit nerve racking when it all came together; I was finding out if the measurements I took two years ago would work!
Yup, I spent a lot of time looking at his trailer.
Thanks for the positive feedback! Let me know if you decide to build a bigger trailer so I can watch your build.
Images: 806
Postby bdosborn » Sun Jan 31, 2010 1:39 pm
For fun, we camped out in the driveway last night and tried out the Magma grill I mounted on the tongue. I grilled a medium rare steak and it came out great.
Here's the grill in the extended/cooking position.
Its tapped of the main propane tank so we don't have to use the little green containers anymore.
Here it is in the travel position.
The Magma grill is pretty spendy but I found a lightly used one on eBay for a lot less than a new one. We grill just about everything we don't cook in the DO so I don't mind spending more on a nice grill and the Magma is the only grill I could find that had a different kinds of mounting hardware.
Images: 806
Postby synaps3 » Sun Jan 31, 2010 2:08 pm
An old friend of mine had a Magma on his boat. They're good grills. :thumbsup:
-- Dave
Build log: here
synaps3
Images: 254
Postby Steve E » Sun Jan 31, 2010 10:17 pm
Bruce,
Very nice job you have to be proud of your build.
Really like your craftmanship and well thought out plan.
Steve E
:thumbsup: :applause:
Steve E
Postby bdosborn » Tue Feb 02, 2010 9:15 pm
Thank you!
Images: 806
New TTT - The Boxcar - Weigh in..
Postby bdosborn » Sun Apr 11, 2010 11:49 am
I had the trailer weighed yesterday on the way home from the first camping trip of 2010. Jean's traveling so it was just Misty and me for a quick overnight at Crow Valley Campground.
The axle weight is 2,460#. I didn't have the tongue weighed but that's at least another 300#. :shock: The good news is that the trailer was fully loaded with all our gear as well as water, propane and diesel so it won't get much heavier in the future. I'm glad I stayed with the 3500# axle, I almost went with a 2500#. The tires are rated for 1,820# each so I'm good there. I bumped the tire pressure up to 45 psi, which should give me a 75 mph top speed according to Goodyear.
I'm also glad I went with a composite tongue using 2"X3"x1/8" tubing as it should be plenty strong according to Andrews Tongue Strength page. I tried to save weight during the build but I didn't sacrifice on strength - everything is rated to 3,500#. That includes the trailer brakes as I still have to have to stop this pig....
One of the goals for this build was to get every luxury I wanted into the trailer and that adds weight. On the other hand, the truck didn't have a single camping item in it, *everything* was in the trailer (another goal). My guess is that the total weight isn't that far off from what we were at in the teardrop considering all the stuff that used to go into the truck. I wish I'd weighed the tear before we sold it. I bet I could shave 500# off the total weight by emptying out all the chairs, awning, dutch oven, generator, water, etc. Still, I'm over my weight goal by 300-400#.
The truck weighed 7,300# so the Gross Vehicle Weight was 9,760#. I got 16mpg which is amazing to me now that I know how much everything weighs. I guess I better start paying attention to those bridge weight limit signs... :lol:
Images: 806
Postby Miriam C. » Mon Apr 12, 2010 9:08 am
:thumbsup: Still worth it. That "pig" is fantastic! :D
