New lady builder wanna be teardropper in Phoenix area.
Postby robertaw » Sat Oct 24, 2009 11:12 am
Okay, I give up... :oops:
Where did you find pictures and info about the Rondack Lodge? I have not seen it and did a search but didn't come up with anything.
Roberta
robertaw
Images: 56
Rondack
Postby danlott » Sat Oct 24, 2009 11:16 am
Steve is a member on here that built the Rondack Lodge. Here is a link to his website for it.
http://www.campingclassics.com/lodge1.html
Dan
Hoplite Traveler Build thread
danlott
Images: 264
Postby Siouxgirl2 » Sat Oct 24, 2009 6:32 pm
Yeah, what Dan said!!
Siouxgirl2
Images: 69
Postby Siouxgirl2 » Sat Oct 24, 2009 6:49 pm
BTW Dan. What did you decide on your seating area? I kind of like the idea of the U-shaped dinette on the master bed. I am considering doing that but it does change ability to use a more cushy permanent mattress.
Also, have you started yet or are you mainly in the planning stages? I'm a little concerned about a trailer and where I'm going to get it or if my husband will do the welding himself. I haven't figured that out yet. You got an awesome deal... I hope I can find something that works soon.
Siouxgirl2
Images: 69
plans
Postby danlott » Sat Oct 24, 2009 10:06 pm
I will make the U-shaped dinette area on the rear bed. I am not sure what I will do about the mattress though. Maybe just make the dinette, but put in a regular mattress. Atleast that way I will have it if I decide to ever use it. Will see how it goes as I build.
I do not know if I will ever be finish with the planning, even after it is built I will be planning some change or something. I have started modifying the frame as I get time off from work.
I think it will be faster to build a frame that will fit your needs. It took a long time to find the frame I have and I still have to modify it. I will have several hundred dollars into it after replacing the brakes, coupler, tires, and some extra metal. I will save a little money, but it would have been faster just to build my own. It would not cost much more to just build a frame, plus you will get what your really need that way.
Dan
danlott
Images: 264
Postby Siouxgirl2 » Sun Oct 25, 2009 1:22 am
Oh that is good and helpful advice. I guess I'll quit looking and figure out building a trailer. Thanks.
Siouxgirl2
Images: 69
