TENNJIM wrote:The top light inside my teardrop heats up enough to prepare for bed or getting up in the morning. It is 12volts and I believe a 12 watt incandescent bulb. I wonder if it would be a longer term heater with a different cover on it to shut out the light entering the teardrop and radiate the heat. Hmmmm?
Jim B / Utah
Ageless wrote:The 'cheap gene'?
Maybe the name 'David' was wrongly translated from Hebrew?
David
mikeschn wrote:You've seen this one, right?
High Desert wrote:I hadn't seen that before Mike, whats the details on this layout?![]()
starleen2 wrote:How about this:
Same principle with light bulb for heat!Sorry guys couldn't resist
