Ageless wrote:Well . . . . .to be factual . . . . .it's a sabre saw
BrwBier wrote:I see Gage cutting thin material. My question is do any skill/saber/jig saws cut thick material well. My problem is when cutting a curve in anything thicker than 3/4" the bottom of the cut is a smaller radius than the top. How do you stop this? Is this where a better saw will help?
Brwbier
Need advice and/or direction. Where can you get a 1/4" router bit with a 1/4" roller guide? I've been looking but can't find one.madjack wrote:......one of the main reasons I like the router, is you can use the proper sized bit to get the proper gap around the door much easier than you can with a jig saw.............
Brwbier
Gage wrote:Need advice and/or direction. Where can you get a 1/4" router bit with a 1/4" roller guide? I've been looking but can't find one.madjack wrote:......one of the main reasons I like the router, is you can use the proper sized bit to get the proper gap around the door much easier than you can with a jig saw.............
madjack wrote: ...since I was referring to a plunge router with a template bushing guide, I am not exactly sure what you are wanting BUT you might try here
http://www.mlcswoodworking.com/shopsite ... tom_anchor
Brwbier
